Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-15-2021, 12:11 PM
taylor4814 taylor4814 is offline
Default How To Drag Drum Clips Into Their Respective Tracks' Playlists?
The drummer recorded his kit remotely (9 mics) and did 8 takes of the song, and sent me all the files.
I have created 9 tracks, grouped, for the drum kit. Then created 8 playlists for the takes, plus 1 more to be the main (target) playlist.
The files are all in the clip bin, well organized. I can easily select all the clips for a given take, but how can I drag them onto the playlists such that they each drop into their respective track's playlist made for that take?
Old 01-15-2021, 02:03 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: How To Drag Drum Clips Into Their Respective Tracks' Playlists?
I think you'd have to have your tracks in the same order (probably alphabetical) as they are in the Clips bin. Then, if the tracks are grouped, you should be able to drag and drop them into the proper playlist.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
making playlists for selected clips?? Felix macOS 2 07-27-2017 08:36 AM
Drag clips from severals tracks to one same tracks simonyeah Post - Surround - Video 19 03-04-2016 01:28 PM
Drag Clips = Delete Clips??? Connor macOS 2 07-09-2012 07:50 PM
Drag and copy clips superproducer Pro Tools TDM Systems (Win) 5 01-08-2006 04:56 PM
comping drum trcks. using playlists instead of new tracks caz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2002 03:29 PM
