Dynamics III De esser problem at 192kHz
I have tried instantiating the De esser of Dynamics III in a 192kHz session, and I get the following error:
The plug-in could not be made active because there is not enough DSP (error #-7077). This happens even in a new session, with one mono track and one stereo master fader, nothing else on it... on an HD2 system, running on a G4 dual 1.2, 1.5Gb RAM, OSX 10.4.3 with plenty of TDM slots available. Interestingly, all other plugs in the Dynamic III group instantiate and work fine at 192kHz... I tried erasing preferences, etc. and also reinstalling the Dynamic III plug, but it still doesn't work. I tried the de esser on a 96kHz session and it works fine at that sampling rate. Are there any known problems with the de esser at 192kHz or is it just that it only works up to 96kHz? The documentation states all should work up to 192kHz.... |
Re: Dynamics III De esser problem at 192kHz
Nevermind.....
I just found the explanation in the readme files... Note to self... read the manual! De-Esser Available at Sample Rates of 176.4 and 192 Only for HD Accel card users (Item #70623) Due to the resource requirements of high sample rates and the complexity of the De-Esser’s operation, a single instance of De- Esser at a sample rate of 176.4 or 192 cannot be instanced unless you are using an HD Accel card. |
no problem with dynamics in pt 8 problem with rane series dynamics at pt 8 | vageli | Pro Tools TDM Systems (Win) | 0 | 01-25-2011 10:00 AM |
problem with dynamics in pt 8? | vageli | Pro Tools TDM Systems (Win) | 1 | 01-25-2011 09:50 AM |
Problem with Waves De Esser automation | Bungle | Pro Tools TDM Systems (Mac) | 1 | 08-28-2008 07:03 AM |
Problem on doing 24bit/192khz Project | keroic | Pro Tools TDM Systems (Mac) | 1 | 08-17-2008 11:43 PM |
De-Esser 3 problem | DustinWhitt | Pro Tools TDM Systems (Mac) | 1 | 10-10-2006 01:09 AM |
