Re: 24 bit session to mp3
Exactly my thought. Don't bother yourself if the final format is going to be mp3.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
And when you are bouncing only mp3, the bit depth option will grey out and switch to 16 bit but it is actually bouncing at the bit depth of the session and therefore does not need dither.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 08-29-2018 at 02:31 PM. |
I drag my 24bit/48k wav bounce into iTunes, and and use iTunes to convert to MP3 at 320kbps. It works, and the MP3 sounds pretty good. The MP3 is VBR at 48k.
What exactly happens during this conversion process? I can't find a solid tech explanation. Anybody?
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
I understand your thought but I think to dither first and then compress to a 16 bit MP3 is the correct way to do it.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
I thought iTunes converted to MP4?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
By default, yes. You can change the settings to all the formats it supports including wav and aiff. Sent from my iPhone using Tapatalk |
What do you mean ‘what happens’? Its converting to MP3. There’s plenty of info online about how the algorithms and codecs are designed. Sent from my iPhone using Tapatalk |
Link? I'm not finding a decent tech explanation. Algorithm workings? Read all 24 bits or truncate during conversion? How does it decide what audio data to toss? Detailed algorithm tech explanation - i.e. what exactly happens during this conversion process?
Save session, close session, open session next day...clips have moved. | ptr22 | Pro Tools 12 | 8 | 02-18-2016 06:34 AM |
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 | doubtful guest | Pro Tools TDM Systems (Mac) | 1 | 02-06-2013 03:42 AM |
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session | chrisdee | Virtual Instruments | 21 | 10-07-2011 10:02 AM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
