Disk Utility/CCC
Hi.
Why can I only get 128 Gb from a 200 Gb disk when using Apple Disk Utility to format a FW disk? I need 133 Gb to clone my system disk, and my 200 Gb disk is too small. I don't get it.
Re: Disk Utility/CCC
What enclosure are you using? |
Ahh, I see. The enclosure is a bit old, it could be the reason.
I didn't think of that. I'll check. Thanks a lot.
I have a new 150 Gb SATA disk laying around - can I take out my SATA sample disk - install the new SATA - format it - and clone my system disk - then swap SATA disks again and start working?
Should work fine.
I love CCC. |
Thanks for replying.
You know, I managed to get the system disk down to 126 Gb, so I tried to clone it to my 128 Gb disk. I started cloning, but when I came back 28 hours later, it wasn't finished. I figured this happened because my target disk was getting close to full. I aborted the cloning, and installed a new 150 Gb SATA disk. I've formatted it, and started cloning the system disk again. We'll see how it goes this time. I guess it's better to have some overhead on the system backup disk too, right?
Cloning to the 2nd internal SATA went smooth. And "hitshack" - you were right. The enclosure supports no more than 128 Gb.
I'm now enjoying 7.2. Thanks to all.
Cloning my disk with "Disk utility" good choise? | petmar | macOS | 15 | 05-17-2011 12:46 AM |
Apple disk utility repair disk permissions | vga | Pro Tools TDM Systems (Mac) | 8 | 05-11-2010 11:10 AM |
disk utility | Tuur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-06-2006 09:34 AM |
Which disk utility are you using?? | RhodesB3 | Pro Tools TDM Systems (Mac) | 4 | 03-04-2006 07:36 AM |
Disk Utility ? | Bluetide | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-24-2003 07:00 PM |
