A simple way of fixing that high pitched whine for Mbox 2.
I've made numerous topics asking about how to fix this situation and nothing worked. You should however have the following:
1. Shielded speakers 2. DI boxes with ground lift switched "on" 3. A power conditioner 4. Balanced cables eventhough the PT says the Mbox 2 has unbalanced inputs/outputs...whatever. 5. The most important key! Make sure your gain knobs are turned down all the way and make sure your instrument is at its highest volume and adjust the gain knobs according to the levels to prevent peaking! You should have your instrument's (keyboard, guitar) volume all the way up or close to the maximum. When I found this out I was like ??? After my 2nd Mbox this is all I needed to know. Anyway, my gain knobs barely see 8:00 lol so hope this helps out anyone else. Oh yeah, if you guys knew this already.... oh well! I'm having too much fun with these smilies |
High pitched whine/noise with mBox h/p o/p into active monitors | audioboffin | Tips & Tricks | 0 | 10-25-2008 06:23 PM |
High pitched audio whine from Mbox 2 mini | jdubes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-30-2008 04:49 PM |
HPF = high pitched whine | Chris Coleman | Pro Tools TDM Systems (Mac) | 4 | 02-23-2006 09:53 AM |
mBox and PT 7= High Pitched Whine | Dr.Quest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-24-2005 10:20 PM |
Mbox- high pitched whine on outputs | Irl Sanders | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-01-2002 01:36 PM |
