Tape plugin, what you guys using?
I have HEAT on my sessions all the time and have always had Slate VTM on the master bus, but today I decided to experiment with waves Kramer and McDSP AC202.
Interesting, as I found Slate VTM to be very subtle compared to Kramer and AC202. I couldn’t get on with Kramer but AC202 I found to have some nice pleasing effects. What I did find annoying about AC202 is that it always increased the output quite a bit, so I had to lower the output so I could compare things properly without louder being better. I went through some of the tape models and became quite fond of the Swiss one Just wondered what you guys are using, or what your views are on some of the tape plugs out there :) Sent from my iPhone using Tapatalk
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Tape plugin, what you guys using?
I have been using the Waves J37 it's a lot subtler than the Kramer. Or can be. A lot of the Izotope stuff I use has some sort of tape emulation that I throw on sometime. Mostly just the J37 though
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Nothing most of the time unless a track or mix really asks for tape, then I use J37. However I don't make a distinction between tape and other types of saturation, I just use the one that makes it feel right and carry on. Different types of saturation have different influences over the frequency curve and that definitely is a factor. I've been experimenting with the different tape algorithms of the Soundtoys plugins but most if the time J37 is the first choice because it has so many options...
Love the topic, though
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Slate VTM is as close to tape as I've ever heard.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
UAD Studer A800 on tracks, UAD Ampex ATR-102 on the Master.
UAD Studer A800 and Waves J37 on tracks, both great and different enough from one another.
I own the UAD ATR-102 and it’s wonderful- HEAT is on all the time
I believe I own the J37 but I don’t think I even use it...I will have to try it out
I like Softube's Tape on the 2bus. I'll spare you my review and just redirect you to Michael White's excellent 'Plugin Of The Week' video; https://youtu.be/DfZAjCfaOwY
For me, most times the 'A' setting (Studer) @ 30Ips seems to do the trick. Maybe dial in a little bit of 'Cross Talk' to sort of centre or solidify the bottom end. A little bit goes a long way. The Start/Stop buttons are a great added feature, sounds so much cooler than Vari-Fi. T
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
Interesting to hear lots of people use J37. Do softtube do a TDM version of Tape, id love to try that if they do.
No other AC2/AC202 user here??
Raoul Crane
Maybe look at Avid real tape if you want TDM. It works very well on most things. For me, Heat, UAD studer A800. Occasionally J37 or Real Tape I have Slate VTM but didn’t like what it was doing to the low end when driven and ended up bypassing most of the time. Chris
HI GUYS please help with REWIRE PLUGIN! | ricardopr14 | Pro Tools 10 | 3 | 11-09-2015 09:14 PM |
TDM tape plugin?? | Raoul23 | General Discussion | 1 | 07-02-2014 04:54 PM |
Tape delay plugin for LE? | psychoth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-20-2005 03:35 AM |
OT - any of you guys tried thy Tape Op forum? | silence_of_stone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-24-2003 12:16 PM |
DUY DaD Tape Plugin | brad719 | General Discussion | 2 | 03-20-2001 12:52 AM |
