Old 06-15-2001, 09:11 AM
jasons jasons is offline
Default Any way to make sure Mono tracks are left and right ?
I imported an omf stereo track from fcp2 into my PTle5.1 and after all the conversions are done, PT lays in two mono tracks into the timeline. I'm supposed to be able to pan one hard left and the other hard right and achieve a stereo sound, but instead i'm loosing sound. Is there any way to check and see if my mono tracks are a left and a right ? If they aren't (maybe they are both right and that's my problem, because when i pan hard right on both the audio is fine) is there any way to change them to both a left and right ? I hope this makes sense, thanks in advance, jason.
Old 06-15-2001, 11:38 AM
marcoustic marcoustic is offline
Default Re: Any way to make sure Mono tracks are left and right ?
Hi!
Just do this with a track with extrem pannings (a song with a HighGain guit left and a clean guit right etc.).
Then you´ll see what´s left and whats right.
But what do you mean by "loosing sound" ? A lower level? A phasy tone?
Markus
www.marcousticaudio.de
Old 06-16-2001, 01:24 AM
Sugarite Sugarite is offline
Unless you have to apply separate effects to each side, you should set it up as a stereo audio track, which would automatically hard-pan the tracks. Otherwise you can't apply stereo effects, only dual mono.
Left, Right & Mono Master Faders stormselah VENUE Live Sound Systems 1 09-12-2011 08:54 AM
Left Channel (not Mono sum) audio only AnMorrigan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-21-2009 05:45 AM
Waves Multi Mono Plugs Only Effects Left Channel Now ThaRemedy General Discussion 2 04-11-2009 06:23 PM
recording at 192 bounces to mono summed left only driftwood Pro Tools TDM Systems (Mac) 0 09-10-2004 01:09 PM
bouncing 2 mono tracks not hard left/right for cd floplight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2003 06:16 AM
