blue timeline arrow misbehaving - badly!
i have several (i assume) graphics issues that all appear when i open up an insert like DB-33, Grand Piano or expand!2....... -When an instrument graphic like the virtual hammond thing opens up it looks like a new screen appears over the top of the normal one. Everything in the new screen moves downward and leftward about ten pixels, leaving the old screen with its now non-functional normal menu in place and behind the new one. -The text is too large in the titles on top of the "Edit:" and "Mix:" windows (not that big of a deal) -The up and down and left and right sliders on the lower and right sides of the screen will move things around on the screen like normal but when you let go of the slider it snaps back to the original position. (a pain in the ass but i get around it by using the arrows) -Ya know the row of menu selections at the top of the screen? File, Edit, View, Track etc... Well a new row of selections appears just below the normal ones. Their font size is too big to fit so you can barely read them. The normal ones are rendered inactive and you have to use the new row to make menu selections. (a little dorky, but the selections still works) Compared to problems like over population, global warming or Taylor Swift's belly button issues these are miniscule, but here is a problem that is hard to live with...... -When I try to pull the two halves of the downward facing blue time arrow apart to do a punch in/out, they jump all over the place, like 40 measures even. The two little flags do the same thing. This means that punching in and out is im-f***ing-possible. This requires me to be talented enough to do a take with no mistakes! i have a Dell M6700 laptop. i know laptops especially non-apple ones are poohpoohed here, but hey it's what i got. In said Dell there is a nVIDIA Quadro K3000M graphics card. In the Pro Tools requirements they specify nVIDIA Quadro 2000 and/or 4000 (at least for Pro Tools 10 (where did the requirements for Pro Tools 11 go to anyway?)) They don't mention 3000. Is that a problem? Also the K3000M is the new and improved version of the older Quadro 3000. Is the Quadro K3000M too good for Pro Tools 11? That couldn't be! Could it? NNNNOOOOOOO!!!!!! i had a previous post about graphics issues and in that one i was advised to reload my graphics driver. i haven't done that yet. One reason is a little touch of techno-retardation/phobia/laziness on my part, and the other is wondering if this K3000M thing is going to work in the first place. Any suggestions anyone? If i upgrade to the latest Pro Tools or Air Creative Collection will that help? Do i need to get a clunky old 3000 or a 2000 or a 4000 and try to install it myself? (i hope that is not recommened) Sandra Says . . . . . Pro Tools 11.2.1 Avid M Box Pro Computer Model : Dell Precision M6700 Serial Number : 7KF**** Chassis : Dell Laptop Mainboard : Dell 096J9P Serial Number : /7KFJLV1/CN1************ BIOS : Dell A11 08/27/2013 Intel vPro : 8.01.40.1416 Total Memory : 15.9GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz (4C 8T 897MHz/2.69GHz, 900MHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC PGA988 (G2) Chipset Memory Controller : Dell Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 8GB DDR3 SO-DIMM 1.6GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Samsung M471B5273DH0-CK0 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : Samsung M471B5273DH0-CK0 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : Samsung M471B5273DH0-CK0 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : Samsung M471B5273DH0-CK0 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : LG Generic PnP Monitor (1920x1080, K6PJ1€173WF1 , 23.9") Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.3GHz, 320kB L2, 2GB DDR3 1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : nVidia Quadro K3000M (576SP 3C 653MHz, 2GB) >>> driver version 9.18.13.2762 10/28/2013 <<< Compute Shader Processor : NVIDIA Quadro K3000M (576SP 135MHz/653MHz, 2GB 648MHz/2.8GHz) Compute Shader Processor : NVIDIA Quadro K3000M (576SP 135MHz/653MHz, 2GB 648MHz/2.8GHz) Storage Devices SanDisk SDSSDP128G (126GB, SATA600, 1.8", SSD) : 117GB (C:) Seagate ST9750420AS (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache) : 699GB (D:) MAT****A BD-RE UJ252 (SATA150, BD-RE, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 117GB (NTFS) @ SanDisk SDSSDP128G (126GB, SATA600, 1.8", SSD) Hard Disk (D:) : 699GB (NTFS) @ Seagate ST9750420AS (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache) Optical Drive (E:) : N/A @ MAT****A BD-RE UJ252 (SATA150, BD-RE, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell Panther Point LPC Controller Audio Device : Dell Panther Point High Definition Audio Controller Audio Codec : Integrated Device Tech 76DF Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Dell Mobile SATA RAID Controller Disk Controller : Dell Integrated MMC/SD controller USB Controller 1 : Dell Panther Point USB xHCI Host Controller USB Controller 2 : Dell Panther Point USB Enhanced Host Controller #2 USB Controller 3 : Dell Panther Point USB Enhanced Host Controller #1 FireWire/1394 Controller 1 : Dell 1394 OHCI Compliant Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) 82579LM Gigabit Network Connection (Ethernet) Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Wireless Adapter : Intel(R) Centrino(R) Ultimate-N 6300 AGN (802.11n (HT), AES-CCMP, 52Mbps) Power Management Battery No 1 : SMP DELL RY6WH21 99.90Wh/7.91Ah Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 6.6 |
Re: blue timeline arrow misbehaving - badly!
Issue solved!
I had the setting for font size too large in control panel. control panel/fonts/change font size/medium (or smaller if your eyes are up to it) I had it set to "larger". |
loop in timeline doesn't work red arrow | damasio | Getting Started | 3 | 06-16-2014 11:59 PM |
Blue arrow in timeline | jefflennan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-17-2009 08:57 AM |
Blue Arrow by the Timeline Insertion Marker | ray271 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-17-2007 06:49 AM |
Pro Tools 7.1 HD badly misbehaving | NTK | Pro Tools TDM Systems (Mac) | 2 | 10-20-2006 03:28 AM |
plug in help needed badly, very badly | brentjd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-28-2006 05:37 PM |
