PT HD9 (running native with motu) running out of memory
Just wondering if anyone else had had this issue... i'm runnning a 8 core harpertown and once i get to a certain amount of plugins in a session pro tools eventually says critically low on memory and gets crumby and finally quits.. it also wont save sessions at this point... im running no VI's and just plugins (mostly waves) .. I'm not using more than 30% of the CPU so it should be able to handle more and i don't think i am really using that many .. possibly 35-40 plugs on average! is this normal ? is there any way around this or is this a problem with native plugin counts .. i don't seem to remember gettign this problem with logic or DP .. they seem to be able to handl many more plugs... i have noticed that i am using 4gb memory so assume it is correct.. maybe pt is really inefficient with plugins? ? hmmm thoughts welcome
Re: PT HD9 (running native with motu) running out of memory
This is also a problem in Logic 9 and above while working in 32bit. NOT a problem in Logic 8 (which is why I downgraded back to v.8) Logic in 64bit gets away from this problem but then there are very few plug-ins that are 64bit. This means that logic has to run in bridge mode which makes it much more unstable with certain plug-ins. Don't know why a number of software releases this last year in 32bit have memory issues. Very frustrating.
PTHD6 / C|24 Controller / Euphonix MC Mix Controller / PT v.10.2 Intel MacPro 2.8ghz Quad Xeon / 18gigs ram/ PE6R4 Expansion Chassis w/Core,4 accel,1 process card, 46" & 24" monitors Syn-g www.bulletsage.com |
PT9, Mac Pro, 10% CPU, 2GB mem used, still says Running Out of CPU and/or Memory | LewKellogg | macOS | 3 | 08-27-2011 04:34 PM |
PT running out of memory | Blackers | Pro Tools M-Powered (Win) | 10 | 06-30-2011 12:59 PM |
PT9 running on MOTU 828 mk II? | drBill | Pro Tools 9 | 4 | 02-07-2011 02:42 PM |
DAE Running out of memory... | mandinga79 | Tips & Tricks | 1 | 12-18-2009 08:07 AM |
PT Running out of memory | JohnR424 | Pro Tools TDM Systems (Win) | 20 | 06-11-2009 10:15 PM |
