Old 03-10-2018, 01:58 AM
Stig Eliassen's Avatar
Default Dealing with transients
Hi there.
What's your favorite plugin? I haven't purchased a transient designer/shaper/mangler yet, but now is the time. Tips and thoughts on the subject appreciated.
Thank you.
Old 03-10-2018, 03:50 AM
amagras amagras is offline
Default Re: Dealing with transients
I still use Audio Assault Transient, the one that used to be free and they replaced for a pro version a while ago. I also have DrumXchanger from Plugin Alliance.
amagrasmusic.com
Old 03-10-2018, 05:19 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Izotope's Trash. Semi clunky UI but a lot deeper than appears.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 03-10-2018, 07:11 AM
BScout BScout is offline
I have SPL’s transient designer (used to have the hardware) and Sonnox’s TransMod. Generally favour TransMod. (Or I’ll just use an expander/gate with an eq to build my own which is what they are anyway; in which case it is FabFilter)
Old 03-11-2018, 05:33 AM
Thanks, guys. I prefer to use AAX-DSP plugins, but that's not a "must".
I'm working more and more in the "dance pop" genre, so I'm searching for that extra "bite". And no; I can't quite get what I want from McDSP
Old 03-11-2018, 11:12 AM
Andre Knecht Andre Knecht is offline
Hi Stig,
The Sonnox Envolution is my favorite transient processor out there. Its features and sonics are stellar, and it also is available as a AAX-DSP plug-in. Check out a demo, I suspect you’ll like it.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 03-11-2018, 01:55 PM
TransMod and SPL Transient Designer Plus are both HDX-DSP (TransMod you need to get the HDX version)
Old 03-11-2018, 04:55 PM
Waves Trans-X is multiband, that sounds useful.
amagrasmusic.com
Old 03-11-2018, 05:40 PM
YYR123's Avatar
YYR123 YYR123 is offline
Transmod was the first Transient Designer I owned
But I gave it up for SPL Transient Designer Plus and the SPL is AAXDSP
The Sonnox version is the only plugin that I didn’t upgrade to HDX. I have the EQ, Inflator, Limiter and the TransMod.
TransMod is probably cleaner and more transparent , but I get quicker results with SPL, and it’s got a Mix knob on it too.
Daniel
Old 03-11-2018, 07:39 PM
AlexLakis AlexLakis is offline
Stiggy,
What makes you feel the need to incorporate a transient designer into your workflow? What about using a compressor?
Asking as someone who has owned a hardware TD-4 and many compressors.
Tab to transients bug! smilerecord Pro Tools TDM Systems (Mac) 1 09-26-2009 09:56 AM
003- Monitoring and Transients richardp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-14-2008 06:20 PM
Tab to Transients BrownMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-08-2008 07:13 PM
Have question about tab to Transients Parisstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-26-2007 08:48 PM
Tab to transients Stig Eliassen Pro Tools TDM Systems (Mac) 4 10-25-2006 08:07 AM
