#1221
Re: Intel Core2Duo ... anyone got one working yet?
Hey Sunburst, Would you be able to walk me through the bios check/adjustment? I can get into bios, but I'm not sure where to look. -Matt
PRO TOOLS 9.0.2 | MBOX 2 Mini | Intel i7 950 | Win 7 Ultimate BAE 1272 | Whisper Room | R ø d e N T K | Roland JD-800 Vienna Ensemble Pro | Eleven LE | Metal Amp Room Hybrid | Prominy S C | Steven Slate Drums Platinum | Strike Structure LE | sE Reflection Filter | Peavey ReValver MK III |
#1222
I'm just going out the door, can you shoot a a email with a phone number?
Edit: You've got mail!
#1223
Im starting to build my quad today. Can you post the setting in the bios sunburst?? I have the ASUS P5K motherboard
Thanks John |
#1224
once your into BIOS arrow over to the "Advanced" tab. your looking for the "JumperFree" Field. under AI tuning set it to "Manual" which will open up a new set of Fields, Under "CPU Frequancy" there should be 2 choices FSB1066 and FSB800. Set this to 266 if your running 1066 Memory. Under the same Menu should a Choice called "Dram Frequancy" that needs to be set to "1067" Under the heading of "Chipset" under the "Advanced" tab should be "NorthBridge" Find the field for "Configure DRAM timing by SPD" changing this to disabled should allow you to see the Memory timing that should be 5-5-5-15. UI would not changed anything here just yet just make note of the settings. hitting the ESC should take you back to the main page. hit F10 to exit saving Changes. Reboot. as the POST screen come up you may want to hit the Pause break key and make sure the memory is now running at 1066. hitting theenter key will resume the POST process. After windows has loaded run CPU-Z and double check that the memory is showing that its 1066, their is a Memory TAB on CPUZ for memory and it should show that the timing is set to 5-5-5-15. there are several referances to CPUZ in this thread. The Core Specs thread or you may want to do a google search for it. Hopefully you can decipher my cryptic instructions and get this sorted out. FWIW some where in (I think it was) the README for the latest couple of cs update's DIGI mentions that there was a patch to increase the performance of the original MBox, Not only is there a hit from FW to USB but apparently there is a performance differance between the original MBox and the Mbox 2 series. The 170 number may indeed be correct for a origianal MBOX, Dont be too sad its still on par with an AMD Quad and should be more power than you'll will ever need. If you dont remember configuring the memory than theres a good chance its sitting at DDR2 800 and you will see a big boost.
#1225
Not recommending that this is what you all do, especially if you haven't done it before but these Quads have got some to spare don't worry about that **Was going to put a screen shot in here, but this forum must not support pics.....? |
#1226
Get me your memory specs and I will try to help if you need more help.
#1227
Sunburst/Vocalvoodo,
Thanks for all your help. I didn't get a chance to run the Dverb 2.0 test after we made that tweak in bios (changing memory timing from auto to 1067) I will run the test as soon as I get off of work today and I will post the results. (crosses fingers) BTW.. My Mbox 1 is updated with the latest firmware. Stay tuned! -Matt
#1228
I can't get mine OC at 3GHZ using 1066 memory timings. You're using 800Mhz memory timings right? I can run at 1066 memory frequency with 4-4-4-12 timings at 300MHZ FSB....when I try to run at 333MHz at 1066 memory bandwidth.....no matter what I set the timings to 5-5-5-15 or not....I can't seem to get the puter to boot. I'm finding that 1066 memory is running as fast or faster in terms of response as 333MHz and 800MHZ bandwidth settings. I'm wondering what else I should try. The anandtech article concerning DDR2 vs. DDR3 evaluations had the p5K running at 4-4-3-11 memory timings at 1066 with a 333MHZ FSB at multiplier of 10. I can't get there. John |
#1229
Definitely a new milestone has been achieved recently. We've got some serious DSP power!
The price/performance is jaw dropping and it will only get better in the next few months. It can be done fully native now, there's no denying it anymore. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#1230
Core2duo? | buschfsu | Pro Tools 11 | 12 | 04-20-2013 11:28 PM |
Working between G5 Mac PPC & Mac Intel | csel | Pro Tools M-Powered (Mac) | 1 | 02-12-2009 01:50 PM |
Plugins not working on PT 7.1.1 intel mac | fus007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-10-2007 11:16 AM |
OMF Not working Intel... | Matt82au | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-19-2006 04:20 PM |
2 PROCESSORS WORKING (INTEL)????? | Bugly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 06-29-2006 12:21 PM |
