#21
Re: Todays Key Command Is.........
To edit a group (adding or removing members), select all the tracks you want to be a member of that group and hit command + G to create a new group. Then change the group ID to whatever group you want to edit. Now that group has been edited to include the selected tracks only.
#22
[QUOTE]
First, from the file menu, save the session. Then, hit Command and the Q key This brings you directly to the desktop./quote] I tried this one today, and it really works! I figured out that it even works without saving the session first. Terrific timesaver. |
#23
is there a key command for clear solo?
#24
Option + Click on any soloed track's button to unsolo all.
#25
hold control+option and the keys + or - and you will change the grid (1/4 note...1/2 note... so forth
Life is good !! Marcello Azevedo |
#26
these two command focus keys are alwayz in use...
R: zoom out horizontally T: zoom in horizontally along with... C: cut V: copy Z: undo no need to press the command modifier key... travis. |
#27
ctrl /alt/ option / !
turns your monitor to grey colors. Great for using your ears instead of your eyes.
Audio peace |
#28
Shift Apple 3 will take a picture of your screen and put it on your system drive
#29
Contol and click in any ruler and it adds the corresponding event: tempo change, memory location, meter change.
Great thread! Joel |
#30
Option+control+shift+G - AudioSuite Gain plugin
.......or any other plugin. Doesn't work for me here. I'm on OSX PT 6
Audio peace |
What cabling and connections into todays studios? | digidesigner | Pro Tools TDM Systems (Mac) | 2 | 08-10-2010 05:00 PM |
"...todays most doped foley-artist-tricks" | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-08-2004 03:23 PM |
Need Engineers Input on Todays Recording Industry | Eddie D | General Discussion | 2 | 12-01-2003 10:13 PM |
PT LE 6 upgrade just came in todays mail | mgbasinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 02-09-2003 05:23 PM |
Todays the 15th, Where is it??? | Kenny Gioia | General Discussion | 19 | 02-16-2001 12:51 AM |
