Old 06-30-2023, 02:34 AM
crizdee's Avatar
crizdee crizdee is offline
Default CPU overload suddenly on all sessions!
Everything was running sweet till a few days ago and then I started getting crashes and freezes and often getting the error message CPU overload!
I’ve tried uninstall and reinstall and trash press and removed and switched ram.
The sessions do seem to run with all or most plugs disabled but as soon as I try with full plugin loaded I get the problem.
I’m now thinking it could be the computer CPU itself?
Any good way to check and test the CPU before I go out and buy another computer?
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-03-2023, 08:51 AM
Default Re: CPU overload suddenly on all sessions!
Hmm, Can you monitor cpu temps? Maybe its a heat issue? Or maybe one(or more) of your hard drives is ready to fail?
Old 07-19-2023, 03:25 PM
crizdee's Avatar
I have decided to go with a replacement computer just to be sure its not computer or ram. Also bought new SSD hard drives and doing a fresh install.
Stripped back on some of the hundreds of plugins i had and so far been ok when starting new sessions. But some of the previous sessions are still being a bit problematic. Also unable to auth all my previous plugins as well so in the middle of this all right now.
Chris
Producer, Engineer,
www.ukmastering.com
Suddenly getting CPU overload errors (-1928)... Bambison Pro Tools TDM Systems (Mac) 4 12-05-2009 07:09 PM
Suddenly my external drive won't open PT sessions tobor is king 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-11-2007 03:44 AM
graphics overload on larger monitors, sessions c-post Pro Tools TDM Systems (Mac) 4 05-06-2007 11:17 AM
PROBLEM - PROTOOLS LE SESSIONS SUDDENLY SLOW nickster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-13-2004 02:23 AM
Sessions suddenly opening with a previous version of Protools Chompers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-26-2002 12:43 AM
