Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 03-06-2023, 10:21 AM
Gibbop1 Gibbop1 is offline
Default Sync MP3 to metronome
Hi All,
I'm new to this and this is my first post!
I was hoping that you could help with what I hope is a simple question. I've imported an MP3 into my project (first track) and I've also added a metronome track. Is there a function to synchronize them so that the metronome adjusts to the tempo of the MP3 and then syncs them together?
Thanks in advance,
Gibbo
Old 03-08-2023, 03:32 PM
Default Re: Sync MP3 to metronome
AFAIK, there is no easy way to do this in Pro Tools. I'm not sure about other DAW's, but you should check Ableton/ and Fruity Loops. The way it gets done in PT depends on whether you want the mp3 to follow the click, or want the click to follow the track(what was the mp3 before import). Getting the click to follow the track is probably the better option so check youtube for help on "creating a tempo map in pro tools"(without the quotes). Now if the track was recorded to a click, then it could be as simple as using the TAP function to tap the time while listening to the music, maybe with some experimenting on the BPM setting to match perfectly(again, youtube is worth checking for tutorials). Getting the track to follow the click gets really involved(using Elastic Audio) and the results might not be very good(because Elastic Audio can often cause lots of artifacts that garble the sound).
Old 03-09-2023, 02:10 AM
Thanks Albee I'll check it out on youtube as suggested
metronome help plz! twig 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-27-2010 01:02 PM
Metronome SeventhSeal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-15-2004 06:55 PM
Metronome or whatever ? Skettalee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-23-2004 11:11 PM
metronome robowisa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-26-2003 08:48 PM
How to ear metronome mane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-06-2002 01:14 PM
