Old 05-05-2021, 05:28 AM
crizdee's Avatar
crizdee crizdee is offline
Default Computer fan noise? try this to help...
Only recently discovered these apps for controlling the fans in your computer. can be set to manual speed or set to a schedule or manually turn on full to cool down during a break etc.
Macs Fans Control... free version does most of what you need
https://crystalidea.com/macs-fan-control
For PC...
AngusMonitor... about $12/ £10 a year, or less for 3 years sub
https://www.argusmonitor.com/
Obviously be careful and keep an eye on the temp display. both apps have a temp display so keep checking especially when you start to use them and get an idea of what temps you're running!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-05-2021, 08:48 AM
Ben Jenssen's Avatar
Default Re: Computer fan noise? try this to help...
Another little tool that I find helpful is:
Turbo Boost Switcher for OSX / macOS
It's a simple menu bar item that lets you know the CPU load, fans speed, and temperature.
I find that I keep turbo boost off under light load and get around 60C instead of around 80C.
Old 05-05-2021, 09:45 AM
Marsdy Marsdy is offline
I’ve been using MacsFan Control for a year.
It does help with reducing HDX fan noise. I’m on a 7.1 Mac Pro and the HDX card is the only thing I can hear. I set the Mac fan nearest the card to 1000rpm (one of the three big ones at the front of the chassis.) You can hear it but it’s a LOT less intrusive and annoying than the high pitched HDX fan. The HDX fan still comes on under heavy load but a lot less frequently.
Dave Marsden
UK
Computer noise make70 General Discussion 2 05-16-2003 11:15 AM
computer noise Brian Maxwell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-27-2003 03:15 PM
computer fan noise raywong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-29-2001 12:17 AM
Computer noise through 001!!! Please help... Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-15-2001 05:40 PM
Computer noise (Who has gotten rid of it?) A Chadwick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2001 01:22 AM
