Re: Drum Overheads
Although, usually I can get a good angle to keep hat bleed out of the 57 enough. I usually have a bigger issue with snare bleed into the hat mic. My solution there is a Sterling UMS mic shield(about 6" x 6" shield on a gooseneck). It really helps
Re: Drum Overheads
Re:hat/snare bleed, here's yet another opinion on drum micing. There are hundreds... If (BIG if) you are going for a great acoustic drum sound: Less = more. This is an opinion, so don't fret!!! Tight mic each drum to a separate track, but this is just part of the sound. Use a single top snare mic. I use an SM81 with the 10 pad. Bottom snare mics sound like crap - again, just an opinion. Let the hat bleed into the snare mic; don't worry since the off-axis frequency response of the SM81 (or similar) is useful in this case. Do not use a 57 on snare; see above re off axis coloration. Use a single overhead. (I use a U87 but you could use another mic.) Position this single OH as low as the drummer will allow and point it at the right knee, left for leftie drummers. No hat mic since OH as well as the SM81 snare mic gets plenty of it. Besides, a hat sounds better from a distance than close perspective. The single OH mic is good for 90% of the drum sound but only if: a) drums tuned b) cymbals balanced c) good drummer. Less mics = tighter phase. Check in mono for full-frequency power. For the mix first bring up the single OH mic, pan a bit to one side. This is the main sound of the entire drum kit. Add the snare mic, pan a bit to the other side. Add kik. Add tom tracks as needed. EQ/verb/compress/limit to taste. Except during tom hits (which I edit between hits anyway) it's 3-mics - kik/snr/OH. Try it !!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Re: Drum Overheads
Bump just to reiterate that a single omni overhead can sound really good. And sometimes it is good to cut back on the complexity. A mic on everything can put you into surgeon mode instead of audio engineer mode. Adjusting 12+ mics and trying to keep an objective ear is almost impossible. For me, at least.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Re: Drum Overheads
Another snare alternative is the Audix i5. Bit more "scooped" with a smiley response than a 57 but it's a great mic and bargain to boot. Works really well on guitars cabs as well Nothing wrong with LDC mics as overheads. Also, if you already have a good LDC, consider spending ALL your overhead budget on a quality small diaphragm mic like a Schoeps or DPA 4006/4011 and use a M/S overhead pair. Your room is probably a bit small for this though but you'll end up with a great mic for acoustic guitar etc. and you can always add a second when budget allows. (You don't HAVE to have a matched pair.) Ribbon mics are great if retro is you're thing but you NEED the right mic pre that caters for them.
Dave Marsden UK |
Re: Drum Overheads
Dave Marsden UK |
#16
Re: Drum Overheads
I have ordered some more bass traps to fill the corners...(I'm on a budget so need to be careful with my spends...) I'll look at filling the wall and ceiling parts next month when I get paid :) I'm happy with the sound of the SM57 on the snare. And the B52 is doing its job after removing the front bass head and moving the mic closer to the batter head. Quote:
TBH I'm satisfied with the SM57 on the snare...The Hayman 1972 snare drum is a cracker... |
#17
Re: Drum Overheads
4 mic setup
Audio Technica AT4041 https://www.youtube.com/watch?v=07KQk4YTde8 They sound great to my ears.... http://www.thomann.de/gb/audio_technica_at4041.htm I think I need to narrow down my choices and stick to a budget of around £500Sterling. Or I will go insane with choice. |
#18
Re: Drum Overheads
They work fine on acoustic guitar but as I say, they are quite bright. The old KM84 was probably THE go to mic for acoustic guitar but was less fizzy. I really like the KM184 on hi hats.
Dave Marsden UK |
#19
Re: Drum Overheads
As an aside since we also seem to be getting off the topic of overheads mics is an interesting one - mic a cymbal from the underside and run it through a Leslie sim. Gives you a different sound that may just work when nothing else does for cymbals. |
#20
Re: Drum Overheads
The UK price on the C-1 seems way high as they are $599US. KM184's would not be on my list(they are no KM84, for sure). I would take a pair of Miktek C-5's over the 184's, but I still think the Rode's will be fine C-7 is good on acoustic too. Royer's are great as well
OT M-S Drum Overheads | flommer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-13-2006 07:33 AM |
Drum Overheads - How Do *You* Like to Mix? | rockrev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-28-2005 02:42 PM |
Drum Overheads | skylab001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-25-2004 05:51 PM |
drum overheads | mbuono | Tips & Tricks | 10 | 11-20-2003 11:10 AM |
Drum overheads sound without overheads | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-12-2003 06:57 AM |
