Dynamic Delay "Pong" help
Hello,
I noticed when using the Dynamic Delay Pong setting the delay taps get softer in volume from right to left with each delay hit. Is there a setting that will make each right/left tap stay the same amplitude and "walk down" in level, in pairs vs. each tap? This is giving the sonic impression that the guitar is panned more to the right because each tap in the right side is always louder than the left. And with slow solos makes it seem off center. I had another red bean device that shall remain nameless and with its pong the hits would stay at one level right then left, getting softer right then left, etc. That made it seem like the guitar was "centered". Is there some setting somewhere I am missing? Thanks in advance |
Re: Dynamic Delay "Pong" help
I think thats how it works, thats how its always worked for me anyway. You can try upping the feedback and mix to hear it a little better, maybe adjust the width a bit narrower as well.
Another thing to try, instead of the Pong, use Mono and adjust the ratio to 50:100 (or 100:50)
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
"use Mono and adjust the ratio to 50:100 (or 100:50) "
That was exactly the sound I was after! Thank you!! |
Sweet!
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Should I use the "h/w insert delay" feature with Symphony io in USB Mode? | Blake Henderson | Pro Tools HDX & HD Native Systems (Mac) | 8 | 09-04-2011 11:38 AM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
Horrible Delay and Reverb on "record enabled" in PTLE 8.0 | jbandhisguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-28-2009 10:32 AM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
