Old 11-01-2012, 10:29 PM
smpkeys smpkeys is offline
Default Automation won't clear on some tracks
Pro Tools 10.3.2 - I have a few tracks that I can't remove automation from. I've tried both selecting the Volume view, and pan view, selecting from right to left and deleting, and also "edit/clear special/all automation", and these tracks still go right back to where they were when making a volume or pan change.
I found a workaround to be duplicating the track, and deselecting "automation", but I've got this in 9 songs. - That's a pain, not to mention the extra size being added to each song from duplicating tracks.
These particular tracks were imported for each song from a template.
I've even tried selecting All (in Groups), selecting 20 min worth back to 0, and doing both of the above.
Why does any automation at all remain after clearing special/ all automation - isn't that the point of that function?
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Old 11-02-2012, 10:43 AM
Default Re: Automation won't clear on some tracks
I've even tried opening all playlists and selecting all, to be sure there wasn't any automation on a play listed region. Still doesn't remove the automation.
Old 11-02-2012, 08:56 PM
Andrew. D Andrew. D is offline
This may be a long shot but I have always believed that the clear special commands have only ever removed automation where there are audio files. Invariably if I import track information from another session that has automation and I try to clear it, it won't clear any more than where the audio files are in the time line in the current session. When I zoom out on the session there is usually automation further up the timeline that is left untouched by the clear command.
I have found this in any version PT I have used.
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM
Mac OS 10.14.5
ProTools Ultimate 2021.6
HD Native PCIe
Apogee Symphony I/O
Avid HD I/O
192 I/O
Waves DLI
Apogee Mini Me
Mbox Micro
Old 11-06-2012, 10:05 AM
I've also had an issue with some tracks that I'll manually try to clear volume automation on (a track imported from a template with NO automation), yet as soon as I hit play, the volume jumps up to where it was. This was trying both select and delete, and using the clear special options.
Anyone seen this and have a workaround?
Old 11-06-2012, 10:36 AM
Stig Eliassen's Avatar
Have seen this, and to fix it:
  1. select all tracks
  2. hit Return so the cursor jumps to the start of the session
  3. hit forward slash on numpad twice
  4. type in 9999999999 (as many as is allowed) for the selection end point
  5. hit Enter
  6. edit > clear special > all automation
Old 11-06-2012, 02:38 PM
Thanks Stig, I will give that a try.
Old 11-07-2012, 02:16 PM
Hi PT Lover,
That's working perfectly -thank you! I'm going to print this and keep it near at all times
Old 11-08-2012, 01:18 AM
Hi PT Lover,
Sweet! Glad it helped.
How do I clear ALL automation from a session? albee1952 Pro Tools 11 3 09-25-2013 01:58 PM
select all/clear automation basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-07-2009 01:52 AM
Clear All Automation TCLguy1 Pro Tools TDM Systems (Mac) 3 02-29-2008 08:53 AM
Clear Special - All Automation Brad Newman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-20-2007 06:00 PM
Clear Automation 4times4mil Tips & Tricks 2 12-01-2006 04:15 PM
