Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 10-30-2012, 05:54 PM
NuovoCello NuovoCello is offline
Default CPU error
Hey there,
I have a question on a particular problem I have been experiencing.
First of all, I am currently using a Mac OS X version 10.5.8, dual 2.5 GHz PowerPC G5, with 6.5 DDR SDRAM. I use this computer for strictly recording purposes only, no internet. Most the songs I save on an external drive. The recording software I use is Pro Tools M-Powered version 8.1.0. And my audio interface is a M-Audio Pre USB Mobile.
I have run up to 16 midi tracks and 25 audio tracks on one session. Everything runs fine unless I exceed those numbers (usually).Then of course I see that pesky CPU overload error. The strange thing is, the only other time I see this error is with drum tracks. I may have one guitar track with a snare track, Hi-hat track, and bass track, and the error will occur. This only being four tracks at playback, and I get an error? Where as I stated previously, 25 audio tracks of all kinds of instruments except drums and it will not error until I exceed that. Does drums take up a lot of memory? I thought I had plenty of RAM. And I do not believe it is because I have to many plug-ins. I don't use much. I have tried changing the playback engine settings and buffer size, but it still doesn't work. I have also tried watching the system usage and the two things that climbs are CPU- usually only to about 18%, and the disk climbs to about 26% and then climbs rapidly to 90% when the error occurs.
Not sure what the deal is?
Much obliged and thank you,
-NC
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Scorch store transaction error. You succesfully paid for this score but an error..... deepfriedpizzainbatter Avid Scorch (iOS) Forum 9 11-07-2011 06:08 AM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
