9073 and 9019 errors
I've read several solutions and defragged my HD several times and nothing has made this error go away. I feel like my laptop is doomed to never properly use pro tools. I'm providing my Sandra Report, I'm a noob to this stuff so please bare with me lol. Thank you for your assistance!
kevin ------------------------------------------------------------------------- Pro Tools 8.0.1 LE (Mbox2) ------------------------------------------------------------------------- SiSoftware Sandra Computer Model : Gateway NV53 Workgroup : WORKGROUP Host Name : Kevin-PC User : Kevin Processor Model : AMD Turion(tm) II Ultra Dual-Core Mobile M600 Speed : 2.4GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : MP Upgrade, Dual-Core Integrated Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 2x 1MB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size Computer Mainboard : Gateway SJV50TR BIOS : Phoenix Technologies LTD V1.02 08/11/2009 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.75GB DIMM DDR2 Chipset Model : Acer RS780 Host Bridge Alternate Front Side Bus Speed : 2x 1.8GHz (3.6GHz) Shared Memory : 256MB Channels : 1 Memory Bus Speed : 2x 100MHz (200MHz) Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 1.8GHz (3.6GHz) Total Memory : 4GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : A-Data HYOVF1B163GZM 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : A-Data HYOVF1B163GZM 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : ATI Mobility Radeon HD 4200 (40 SM4.1, 256MB, Integrated Graphics) Graphics Processor STREAM Processor : ATI Mobility Radeon HD 4200 (40SP, Integrated Graphics) Storage Devices Hitachi HTS545050B9A300 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 7MB Cache) : 466GB (C:) (E:) TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 2kB (D:) Logical Storage Devices Reserve (E:) : 100MB (NTFS) @ Hitachi HTS545050B9A300 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 7MB Cache) Gateway (C:) : 454GB (NTFS) @ Hitachi HTS545050B9A300 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 7MB Cache) PQSERVICE : 12GB (NTFS) protools8 (D:) : 4GB (UDF) @ TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Acer IXP SB600 SMBUS Controller LPC Hub Controller 2 : Acer SB700 LPC host controller LPC Legacy Controller 1 : Winbond WPCE775LA Audio Device : Acer IXP SB600 High Definition Audio Controller Audio Codec : Conexant High Definition Audio (HERMOSA) Audio Codec : Conexant 2C06h Audio Device : Acer RS880 Audio Device [Radeon HD 4200] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Acer SB700 SATA Controller [AHCI mode] USB Controller 1 : Acer SB700 USB OHCI0 Controller USB Controller 2 : Acer SB700 USB OHCI1 Controller USB Controller 3 : Acer SB700 USB EHCI Controller USB Controller 4 : Acer SB700 USB OHCI0 Controller USB Controller 5 : Acer SB700 USB OHCI1 Controller USB Controller 6 : Acer SB700 USB EHCI Controller SMBus/i2c Controller 1 : ATI SB600 SMBus SMBus/i2c Controller 2 : ATI AFS SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet Wireless Adapter 1 : Atheros AR5B93 Wireless Network Adapter (802.11n (HT), AES-CCMP, 130Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.2 |
Re: 9073 and 9019 errors
Switch off the wireless adapter.
Get another hard drive exclusively for your PT sessions.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Your Gateway NV53 laptop does not show up among the qualified laptops for ProTools.
http://avid.custkb.com/avid/app/self...p?DocId=380551 I guess that doesn't mean it will not work, but probably is less likely to work with Pro Tools. Mac seems to be the best option for running Pro Tools on a laptop. |
Turion is not supported(AFAIK)
Turring off wifi is required(as mentioned) Integrated graphics sometimes are a show stopper(why the better Pro Tools laptops have separate graphics card/memory) This link(if you can follow it) will show you what is known to work(and what is known to NOT work)Pro Tools Compatibility Grids
Thanks everyone for replying! As far as a hard drive should I get an external hard drive or swap out my internal hard drive?
Thanks :) |
External firewire drive (USB can't handle audio). Switching your internal won't help you. You need a separate drive to record to, in addition to the drive with the OS and programs (partitioning your drive won't cut it either...)
"Sometimes having limits keeps you sane"- Albee1952 |
So switching out my internal for one at 7200rpm won't help? I really have no idea what I can do then.. My laptop was capable of running pro tools flawlessly before I caught a virus and was forced to reinstall windows a few times. Now it gives me these errors.
That means something is not setup right. Maybe bad drivers, forgotten system tweaks or who knows what. That's why its so important to save drive images or clone your drive. That way(assuming you clone or image when all is working great) its easy to get back to a working setup. Try to review what you had and how it might be different now. Maybe you installed a newer version of Windows? Newer updates that are not helping(like IE8).
The above comments about Turions, drives, graphics and the wireless are spot on. Allthough a few have been lucky with each one of these.
I don't think anyone is saying a faster system drive will not help a little but a separate drive for session audio is highly recommended. When working with a few things against you every little oddity adds up. The slightest OS tweak can mean everything when hardware is marginal. Are you running any other software that was not there before? Keep in mind that the installation order of other programs can affect Pro Tools in a big way. Be sure all plug-ins are current. I've found that a way to help assure a good system can be to keep the computer offline and keep non-music software to a minimum, use only approved and current plug-ins, do all the suggested optimizations and clone your system drive before any changes are made.
Excuse me for being thick, but what do you mean a separate drive? How do I use a separate drive for a laptop unless it's an external drive? I'm still stumped..
DAE Errors 9019 & 9073 PT6.4 LE | bobmiz | Pro Tools SE and Essential (Win) | 3 | 03-14-2013 12:18 PM |
9019 and 9073 errors? | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-04-2010 04:05 PM |
5.3.1 DAE ERRORS -9019, -9073 | charliebeans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-06-2005 12:08 PM |
DAE Errors 9073 & 9019 | shoalbilly | Digidesign Hardware & Software | 2 | 11-29-2004 09:07 AM |
9019 and 9073 errors | juice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-03-2003 02:12 PM |
