Old 07-24-2010, 02:22 PM
Epik Productions Epik Productions is offline
Default Grouped Track Playlist solo shortcut???
Hello,
Is there a shortcut for soloing grouped tracks playlists??
For example
If i'm comping 20 drum tracks in playlist view and i want to audition, lets say, the third take in the list, i press the solo button next to the track and it will play that playlist on that track instead of whatever is on the main playlist. Currently, to do this over 20 drum tracks, i have to manually select the solo for each playlist on every track. Is there a way to select solo on one track and have it affect all tracks in the group?
Hopefully i just missed something, because that would be a real time saver!
Thanks in advance,
-EP
Old 07-24-2010, 02:40 PM
formfunction formfunction is offline
Default Re: Grouped Track Playlist solo shortcut???
Originally Posted by Epik Productions View Post
Hello,
For example
Thanks in advance,
-EP
Search the manual for "group attributes". ff
Old 07-25-2010, 09:51 AM
Sean Russell Sean Russell is offline
Grouped tracks or multi-mic'd tracks in playlist view is a great way to bring out the fail. For single track stuff like vocal it's awesome. For drum stuff, your playlists can get all mangled and you can end up with snare_02 and floor_04 and little way to get back. Save-as regularly. The only good method for this is to not use playlist view but switch between playlists the old way.
Solos don't default in group settings anymore; you have to modify the group to include solo.
... but does it help the chorus?
Solo selected track shortcut Tone Pro Tools TDM Systems (Mac) 8 07-06-2014 08:40 PM
bug report-- solo playlists among grouped tracks only works if mix group is selected Gems Records Pro Tools 11 4 12-26-2013 09:21 AM
playlist solo intermittent in PT9? Fritz Pro Tools HDX & HD Native Systems (Mac) 1 04-06-2013 05:09 AM
Grouped Tracks Solo question teacherman Tips & Tricks 3 03-03-2011 12:36 AM
Track Record Enable/Mute/Solo shortcut keys? maufau Pro Tools TDM Systems (Mac) 2 07-06-2008 10:11 AM
