panning automation lost when moving a region?
this is a surprise. 7.2 cs2.
I received a BG session from an editor, cut in 5.1 with a lot of panning built in. When I move a region around, in waveform view, to try to minimize tracks/voice use in the session, I see that the panning automation does not go with it. This completely sux. Is this normal? I was under the impression that when moving a region in the waveform "master" view, all automation, including plug in automation, would go with it, as long as you were moving it to a track with the same set-up. this is not true at all with panning automation. Is this a BUG? Damn. |
Re: panning automation lost when moving a region?
"automation follws edit" is selected, btw.
Moving audio region without moving automation? | tokolosh | Post - Surround - Video | 6 | 04-09-2014 06:11 AM |
EFX and panning lost on bounce in PT 9 | masola1 | General Discussion | 1 | 10-04-2011 08:22 PM |
When moving a region from 1 track onto another region... | Violet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-30-2010 10:53 PM |
First note in region is lost after copying/duplicating region | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-22-2009 04:46 AM |
moving region without any automation | bad jitter | Pro Tools TDM Systems (Mac) | 4 | 12-31-2007 04:17 PM |
