Old 06-30-2000, 12:18 AM
hanszy7 hanszy7 is offline
Default HEADPHONE BLUES
Ok, I'm recording with 001 & a Mac G4/500, my speakers are NS10M's and the room isn't exactly acoustically treated, so I check my mixes on other systems & they sound almost good.The problem I'm having is with my headphones, where I hear this nasty distortion. There is no hint of it when listening through the speakers(I listen between 87 to 90 SPL C weighted), also the meters never hit the red on individual tracks and on the master fader.I've also checked each plug-in to see if I was overdriving them, and even soloed each track and there was no distortion.The next thing I did was buy a new set of headphones (AKG 240 DF) but still got that distortion (by the way my old ones are AKG 240 600 ohms which are a bit more midrangy then the 240 DF's).The result of all this is that I keep second guessing every move I do in a mix which consumes a lot of time with not much better results. What am I doing wrong? are these headphones not compatible with the 001 interface? The only time where I don't hear the distirtion is when I either lower the master fader's level by a considerable amount or do the same to the headphone knob on the 001.Any suggestions would be really appreciated, thank you.
Old 06-30-2000, 02:56 AM
Wolfgang Eller Wolfgang Eller is offline
Default Re: HEADPHONE BLUES
Hello
Have you ever tried a different headphone amp?
Regards Wolfgang
Wolfgang Eller
SRS Mastering/Germany
WWW.SRS-Mastering.de
wolfgang-eller@srs-mastering.de
www.srs-mastering.de
Mac Pro 6.1-8core, OS 10.13, PT2018, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 06-30-2000, 12:19 PM
jimmyk jimmyk is offline
my head phones start to distort after about 2 o'clock on the digi headphone volume. i have a headphone amp that will give me alittle more if desired. get some good sealed cans, sony or at and you probably won't need to crank it as loudly, i believe yours are open. turn down the output on the front of your 001.
jimmy
Old 06-30-2000, 04:44 PM
Conscious Structure Conscious Structure is offline
I use those exact headphones, but I do my monitor mix through a mackie console. That amp is probably your problem here.
Dave Belazis
Conscious Productions
Conscious Studios
Old 06-30-2000, 07:42 PM
Thanks for responding, I truly appreciate it.
Old 07-02-2000, 12:01 AM
lwilliam lwilliam is offline
Try Sony 7506's or MDR600's (or 900s now, I believe). They have about a 60 ohm impedance vs the AKG's 600 ohm impedance. You certainly should be able to get those loud enough. I only use my 240Ms when I don't have to worry about them being really cranked...and I also use the Mackie headphone amp, but connected to a little Samson $130 5 output headphone amp. It works great for most headphones.
LW
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-13-2012 12:34 AM
10.4.8 Plug In Blues skotch Pro Tools TDM Systems (Mac) 1 10-16-2006 02:19 PM
IRQ blues ..... threesixty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-04-2003 04:16 AM
OT: XP Blues JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-29-2002 01:18 AM
P G & E blues? shaggy General Discussion 2 01-19-2001 08:32 AM
