Old 03-04-2011, 06:36 PM
mirrorboy mirrorboy is offline
Default RE: SSL G Comp / Latency / mix bus chain
Hi All-
Sorry if this is the wrong place to post this, but I didn't see another area that fit.
Anyways, here's what I have been doing:
I'm sending my mix to a Dangerous D-Box (8 Outs). I then take the sum out and run it into the SLL G comp. The SSL stereo outs go back into PT. I then make a Mono Aux track and send the input of the mix from the SSL to this Mono Aux and send this to key the compressor.
The problem is, I've realized the SSL is obvsiouly being keyed after the mix is being sent through.
The other option is to send the mix in to the D-Box, out that and back into tools. Then run a stereo out into the SSL and a Mono out (same way via aux send) to key the SSL. The only thing with this is, I would be using the SSL as the last piece in my mix bus chain.
Wouldn't it make more sense to use the SSL before using something ike UAD's precision maximizer?
Anyways, I've now confused myself and am unsure how to setup the mix bus while still being able to use the mono key input on the SSL AND have it key the compressor at the same time the mix is running through it.
Thanks in advance for your help.
It's much appreciated.
Scott
Old 03-04-2011, 10:39 PM
Default Re: SSL G Comp / Latency / mix bus chain
Sending out to the D-box makes good sense. Passing the Dbox out into the SSL compressor makes good sense(assuming you are NOT going to have the project mastered). Printing the output of the comp back into Pro Tools makes sense. But this: " I then make a Mono Aux track and send the input of the mix from the SSL to this Mono Aux and send this to key the compressor." doesn't make sense to me. Am I the only one?
Old 03-04-2011, 11:42 PM
huzzam huzzam is offline
Yeah a bit confusing. Do you want to key the SSL Comp (which is on the stereo 2-bus) via a side-chain from some other mono submix? Or from the sum from the D-Box (pre compression)?
It sounds like you're making an extra loop — PT -> DBox -> SSL -> PT -> SSL key — but I don't see why.
What do you want the compressor to key off of? The mix, or something else? If the mix, then you don't need to side chain anything into that mono key input, just turn off the key input altogether. If you want the comp to key off something else, why not just sum the submix In The Box and send that out a spare output?
~Peter in oakland
[IMG] code is Off
Delay Comp and Side Chain Issue jimmyzk macOS 15 02-11-2013 05:48 PM
Delay comp and Side Chain Issue jimmyzk macOS 2 10-01-2012 03:46 AM
HPF side chain with mix buss waves SSL comp Raoul23 General Discussion 0 09-11-2012 02:50 PM
Side Chain Arriving Late to RTAS Plug - Delay Comp On holden Pro Tools TDM Systems (Mac) 33 04-23-2012 12:51 PM
Outboard Comp / Pre Signal Chain PTUser NYC Tips & Tricks 1 08-21-2001 01:05 AM
