Old 03-04-2011, 08:45 AM
Richard Spangenberg Richard Spangenberg is offline
Default Best Output for Avid?
Simple question: What is the best file format to export stereo file for import into avid?
I exported an aaf file and imported it and that created 30 or so individual files, non of which provided my remixed audio channel to use in Avid. Then I save a wav file that created a separate left and right wav file that Avid refused to import because it's in conflict with something imported in the aaf file earlier.
What is standard practice for this? Can't seem to find an answer anywhere
Rick
Old 03-04-2011, 04:31 PM
SDDP SDDP is offline
Default Re: Best Output for Avid?
Select the file you want to export then hit APPLE + SHIFT + K, then for
File Type: select Wave
File Format: Select Stereo
Bit Depth:16 (this depends on your session and what the editor wants)
Sample Rate: Rate: 48k (this depends on your session and what the editor wants)
Choose your destination and click Export.
Old 03-04-2011, 04:41 PM
Thanks for the reply...
I suppose that on a PC, one would click Control rather than Apple?
And that this will create a stereo wav file,... Just what I need.
thanks
rick
Old 03-04-2011, 04:43 PM
Do you mean getting a final stereo from a session? If yes, then run the bounce to disk function and select your desired format. If its going to be burned as an audio CD, the go 16 bit/44.1K stereo Interleaved WAVE(if your session is at 24 bits, then insert a dither plugin on the master track). If your mix is going to video, then go 24 bit/48K stereo interleaved. If ht eproject is going to be mastered, then bounce at the same sample rate and bit depth as the session(wave or AIFF are both fine here).
Old 03-04-2011, 05:02 PM
yes, Iam trying to cut a audio file that I can simply import into avid and replace the existing audio tracks with it. The remix is the improved version of those tracks.
Sounds like bounce to disca s a stereo wav is the way to go. Will check it out tomorrow. You think avid would make this native.
rk
Old 03-04-2011, 05:23 PM
rick
No problem.
btw, I didn't know you were on a PC. Another option to avoid using Control is sell the PC, go to your local Apple Store, buy a Macpro.
It comes with a Mac Keyboard and that will solve that isssue :)
Old 03-04-2011, 06:49 PM
Sugarnutz Sugarnutz is offline
Originally Posted by SDDP View Post
No problem.
That's not nice!
HD Native Thunderbolt
HD6 Accel in Magma PE6R4 Expansion Chassis
PT HD 10, 11, 12, Ultimate 2018, 2019
Cubase 9.5 Pro
Vienna Ensemble Pro 7
Icon D-Command
HD Omni
192 Analog I/O 8 in/8 out/Digtal I/O
192 Analog I/O 8 in/Digital I/O
Two 192 Digital I/O
Apogee Rosetta 800, AD16X & DA16X (All wth X-HD cards)
Antelope Zen Studio+ Thunderbolt
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.3
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
MacOS 10.14.5 Mojave
GIGABYTE GA-Z97X-UD7 TH
Intel Core i7-4790K 4.4 GHz
32 GB of DDR3 1600
EVGA GTX 760 Video Card
OS X 10.13.6 High Sierra & Win 7 Pro 64 bit
Dynaudio BM5 Mk III
B&W 604 s2
800W 15" Ported Subs
McIntosh MC-7106 Bridged ~ B&W
Hafler P7000 "Diablo" ~ Subs
Old 03-04-2011, 07:01 PM
TOM@METRO's Avatar
Originally Posted by Sugarnutz View Post
That's not nice!
No, but it is funny.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.10 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-04-2011, 07:20 PM
That's not nice!
Sorry, I feel horrible now.
But it is viable option though.
Old 03-04-2011, 07:29 PM
HAHAHAHAHAHAHAHA
Was thinking about doing exactly thatand using final cut pro just before they announce the new Avid 5.0 Besides, got three servers I'd have to change and the laptop.
rk
[IMG] code is Off
Digidesign 192 Analog I/O with Avid Input, Output and AES DB25 Breakouts N1h1l1ty Buy & Sell 5 09-04-2014 11:02 PM
Digidesign Avid 192 Analog D/A output expansion card for Pro Tools HD ghostwriter Buy & Sell 1 04-13-2014 05:35 PM
Avid Omni Input / Output levels Ridder Pro Tools HDX & HD Native Systems (Mac) 15 08-19-2012 09:20 AM
OMF output to avid volume problems egedney Pro Tools TDM Systems (Mac) 5 04-02-2008 10:06 AM
syncing to 24-frame Avid output cheese2 Pro Tools TDM Systems (Mac) 1 03-15-2004 08:40 PM
