Old 01-05-2011, 01:44 PM
georgekant georgekant is offline
Default Re: Pro Tools 9 Crossgrade/Activation Issue
Thanks
Old 01-05-2011, 01:48 PM
necjamc necjamc is offline
You could email the Avid store prior to buying it just to check. at [email protected]
Old 01-20-2011, 08:36 PM
band_master band_master is offline
hey i was having an issue with my crossgrade on a digi 002 and found this thread on google. fyi turned out that i was reading an "A" in the serial number as an "R" because of the font they used. maybe that helps somebody...
Old 01-21-2011, 08:54 AM
Bill Denton Bill Denton is offline
I had the same problem with the font...
Fortunately my 003R box was readily accessible and I was able to put it under a really strong light to read the serial number...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 01-21-2011, 10:27 AM
CME CME is offline
Originally Posted by georgekant View Post
Yes , I understand that I will buy this since I use mpowered protools, but when it asks for hardware serial what should I put? The serial of my project mix? This wasn't bought with protools. That is what I want to know before I spend these money.
From what I understand a PTMP crossgrade only requires you to have a PTMP license on your ilok. It will let you purchase and download 9. But you will have to go to iLok.com and essentially swap your PTMP license for the PT9 one. If you don't have a PTMP license on there ilok won't install the PT9 license.
However with PTLE crossgrades, you have to have a hardware serial number to activate PT9. And yes this is the hardware serial number on the unit. I had no issues crossgrading my system. :)
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
  #16
Old 03-05-2011, 04:48 AM
noblejeanz noblejeanz is offline
That means, even when I only have a hardware serial number from an old interface, which I don't have any more (in my case the mbox 2 mini, but I still own the serial), I can do the crossgrade without having the mbox 2 plugged into my computer? I ask only for the unlikely case, that during the installation the installer checks, whether the hardware with this serial is really in use or so...
  • Mac Pro 1,1 8x2,33Ghz 12GB RAM OS 10.6.6 on SSD, Mac Pro 3,1 8x2,8 12GB RAM OS 10.9.5
  • MacBook Pro 13,3" 2x2,26Ghz 8GB RAM 10.9.5 Optibay
  • Digi003 Rack, Pro Tools HD4, 96, 96i
  • ProTools 11, HD 10
  #17
Old 03-05-2011, 06:21 AM
CME CME is offline
Default
You have to enter the serial number to download the installer. After that you are good to go. The interface doesn't need to be attached for installation.
  #18
Old 03-05-2011, 06:24 AM
thanks a lot!
[IMG] code is Off
Pro Tools 11 Crossgrade LE activation problems please help! listening-books Pro Tools 11 1 12-13-2013 09:38 AM
Crossgrade from LE to 11 activation issue nhlogan Pro Tools 11 5 07-20-2013 07:59 AM
Pro Tools 10 LE Crossgrade Activation Problem BBKBB Pro Tools 10 3 10-07-2012 01:58 AM
Pro tools LE crossgrade issue melodymaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-11-2011 09:35 PM
Crossgrade activation Electrik macOS 1 03-22-2011 10:53 AM
