Old 08-21-2010, 02:37 PM
Armando Armando is offline
Default Audio level lower on left side output
The audio output level on the left side of my monitor setup is lower than the right. I have eliminated the cabling, Control 24 and my Mackie 824s. This leads me to believe the 192 I/O maybe the culprit. The thing is that this happens sporadically and dont know if its a software or hardware issue.
Any tips on what to do from this point? Thanks in advance!
Armando
Old 08-22-2010, 03:50 PM
oliarnalds oliarnalds is offline
Default Re: Audio level lower on left side output
Have you checked if the Reference Levels (Setup - Hardware Setup - Analog Out) are set correctly to the same level for L and R?
www.olafurarnalds.com
Old 08-22-2010, 03:59 PM
formfunction formfunction is offline
Are the level differences showing in the 192 meters? C24?
Old 08-22-2010, 04:05 PM
Sean Russell Sean Russell is offline
Have you calibrated your outputs???
... but does it help the chorus?
Old 08-22-2010, 04:44 PM
Top Jimmy's Avatar
Yeah, what Sean said. Pots need to be exercised occassionally. Rotating the pots and calibrating can resolve this issue if that's where the problem lies.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Issue with 192 left side output Armando Pro Tools TDM Systems (Mac) 1 11-18-2010 06:48 AM
MBox 2 - Audio only on Left Side techkid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-09-2008 11:09 PM
left channel audio is playing at a lower volume nodrog1213 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-02-2004 05:42 PM
Lost left side audio! lgs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-15-2000 08:58 AM
lower audio level than most commercial CD's blairl Digidesign Hardware & Software 6 11-23-1999 04:54 PM
