I/O Settings Changed??? Please Help!!
I have Pro Tools 5.3.1 running on XP. I've downloaded the driver that allows you to use your pro tools interface to listen to CDs as well. It worked fine for a while. Now, every time I enter a session, I get a message that says my I/O settings have changed. I go in and check and it shows no interface as my output. I click on the old settings and it shows my interface used to be used for output.
I cannot find anywhere to change it back and save it. It does this with every session so now I can do is use headphones. ANy ideas on this would greatly be appreciated. Thanks TK |
Re: I/O Settings Changed??? Please Help!!
Anyone? n Could you some suggestions/ Thanks
Did you try hitting DEFAULT? in the I/O settings.... Don't panic with it. Go in there and play with it for a few minutes (so to speak) and you will start to figure how it works. Try the default. Also, when you make a NEW session, when you set it up, select for I/O at the initial creation window to STEREO. That should do it. Sounds like you are selecting the default which is probably set to your last used session when you create a new one.
You can also hit my site and go to the HELP section. There I have templates that I created to use on standard recording sessions. Hope this helps? - Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
That did it. THanks a lot. Really appreciate the help. Didn't see the default button in the corner there. Thanks.
TK |
No prob!
Welcome to the DUC! - Doc
I/O settings changed | Adept | Pro Tools 9 | 5 | 03-07-2012 04:57 PM |
I/O settings changed when upgraded to 8.0.4 | benadams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-06-2010 12:51 PM |
I/O Settings changed problem | Dstryr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-03-2007 09:54 AM |
I/O settings changed? | Elvisaintme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-31-2004 11:32 PM |
I/O Settings changed? | Elvisaintme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-18-2004 11:46 PM |
