Volume Automation: Exact Values
Is there any way you can plug in exact values when using volume automation? I don't want to just jump from 2.0 db to 4.0 if 3.0 works better, you know? Thanks!
Isak |
Re: Volume Automation: Exact Values
Use the fine adjust mode(click on the parameter you want to adjust and then hold ctrl while making the adjustment).
Also, the larger the track is in the edit window, the more subtle the increments become. 2db is the default for "small", but .8db is the default for "medium"...
However, I do wish you had the option sometimes to type in values for various things. |
Possible Bug: Clip slide (option H) values not exact | DEastman | Pro Tools 11 | 3 | 03-16-2014 03:25 PM |
Pro Tools 11 HD: Clip slide values not exact? | DEastman | macOS | 4 | 03-13-2014 01:24 PM |
Exact Plugin Setting Values | strum | macOS | 3 | 05-22-2013 09:23 AM |
Gradual automation of tempo is never exact. | phillyt2k | Pro Tools 10 | 7 | 04-18-2013 09:38 AM |
How do I pan or change the volume to an exact value? | sb_stefan | Pro Tools 10 | 3 | 02-15-2013 04:51 PM |
