bass amp plugin- what do you use?
Title says it all really. What bass amp modulation plugin do you use and recommend for recording bass through di? What do you like/dislike about different plugins?
PT10, Focusrite Liquid Saffire 56, Eleven Rack, i7 950 @3.80GHz, Noctua NH-D14 CPU cooler, GA-X58A-UD3R, Corsair CMD12GX3M6A1600C8 12GB, SAPPHIRE VAPOR-X HD5770 1GB GDDR5 PCIE, Caviar Black 500GB 32MB Cache OS drive, 2x Caviar Black 1TB 64MB Cache Sata3 (Audio and library), Broadcom BCM94322MC wireless network adapter W7 - 312 dverbs @ 64 buffer/ 403 dverbs @ 1024 |
Re: bass amp plugin- what do you use?
IK Multimedia's AMPEG SVX and Sansamp. Those two along with Waves GTR stomps gives me everything I need.
I don't record with any modeling whatsoever.
I record direct through a quality preamp, then add modeling after the fact. Sometimes nothing works as well as good old tried and true SansAmp. I also am known to use the IK Ampeg plug, and have also grown quite fond of Pod farm Platinum.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
I also start with a good DI recording. Then I use an AUX send to an AUX track for the amp sim. I started with sansamp, and it does a decent job. Then I got Amplitube and used a clean tube preamp and 50 watt tube power amp combination, and that was better. Now I have the Ampeg SVX and use what is really the classic SVT setup. That, mixed with the DI is really good(to me anyway). Add a little compression and EQ to the DI track and I am good to go
I run a SVT Classic/810E flat out in a concrete bunker lined with sand bags.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
^^It's true^^, and that's just ONE of his rigs. Bastard!!
Yeah, I have a friend down here that owns 8 of them
He could make it nine. "She"s available.
A huge advantage of going the Clean DI route and then Re-Amping to flavor is the fact that your not vibrating and rattling everything in the room. That was the part about lining the bunker with sandbags. I've been holding out on buying IK's SVX hoping that they will come out with some 11 Bass modules but probably should just buy it.
++1 on IK SVX plug on a DI'ed track... DI in my case is currently a Summit Audio chain... The 2ba into a tla50 which is currently beating out my lunchbox API, Purple Audio, Eisen neveish chains. But the SVX really let's you do a bunch more to the track... All in a good way.
My day job: Wilson Dyer MPSE Sound Supervisor: NCIS Los Angeles, CBS Television |
I've found SVX to be the best. It's really easy to get a great bass sound without too much fuss. In a close second is Waves GTR3. Another thing I do is reamp the bass track thru a bass amp, but with all the plugins on the signal. So you get the same sound, but with a lot more balls. Then I just stack them up.
- Sent using Tapatalk.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
Waves bass ren free plugin | YYR123 | General Discussion | 0 | 11-29-2013 08:51 AM |
Guitar/bass synthesizer Plugin ? | Jayoel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-26-2009 09:50 AM |
Bass Amp Simulator plugin | Matt Darcy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-16-2008 06:13 AM |
tune plugin for bass?? Help appreciated | psus15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-10-2006 09:00 AM |
Bass Guitar Plugin or Applicable Tools | bo fitz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 10-01-2005 11:43 AM |
