Old 10-17-2011, 12:59 PM
Olly Olly is offline
Default Eleven Rack Tuner
I Stopped Taken My Eleven Rack To Gigs Because Of That Damm Tuner
I Used To Spend a 1/2 Hour Tuning UpWith It
It Only Takes Me 3 Mins With My Roland GP-100
Old 10-17-2011, 01:06 PM
Default
The Eleven Rack tuner works fine for many of us.
What ER firmware are you running? What guitar pickups? Going straight into the Eleven Rack? What exactly makes it taks so long to tune ?
Darryl
Old 10-17-2011, 01:08 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack Tuner
Tuner works fine for me as well. For guitar and bass - I tune down to Drop B and it works fine.
Old 10-17-2011, 01:24 PM
Deny Deny is offline
It's not the best tuner in the world, I'll give you that. But it's not the worst either, I can tune with it just fine. Also with all the amp modeling awesomeness, even if it was unusable I'd still take my 11R to gigs plus a floor or handheld tuner.
Deny
My SoundClick Page
Old 10-17-2011, 01:28 PM
udamann88 udamann88 is offline
Did a big gig w/ it & it worked w/ no problems at all..........Not the best...& not the worst tunner either......
Once my guitar adjusts to the temp of the room I'm playing in it stays in tune for a long, long time.....fwiw......
Side note: When you go to a gig or practice get your guitar(s) out 1st thing before you set-up ur other gear......Give them a chance to adjust to the temp in the room......Or maybe your guitar needs to see a tech......I hope you get this all worked out & back to using ur 11R.....
Old 10-17-2011, 02:04 PM
skyko skyko is offline
... the only thing you may call it is too precise, but not bad!
Considering that the 11R is used for studio work too, I'd say that's a good thing. I want my recordings to be very accurately tuned.
For gigs, I'd anyway take a stompbox tuner that mutes the signal during tuning!
Old 10-17-2011, 02:33 PM
moff moff is offline
Unless it's winter, and your guitars have been travelling in the back of an unheated truck\van for a while. If you open your case too soon, the sudden change in temp WILL cause finish cracking . I learned that lesson the hard way many years ago. If that is the case, leave them unopened for about an hour, so the can slowly adjust. But if you're just bringing them in from a heated car, you should be OK opening right away.
Regarding the OP - The tuner in the 11R is fine - as accurate as a Boss TU or Korg - maybe more so. I have mine set up to mute when it's in use, and activate it from my GCP. Also, don't forget that a guitar can never be perfectly in tune; that's just the nature of the instrument.
Old 10-17-2011, 04:00 PM
cessnapilot cessnapilot is offline
All tuners do is make me realize how unstable all my guitars are.
Old 10-17-2011, 04:27 PM
Random Dude Random Dude is offline
I'm kind of picky about tuners, but it's far from bad. It's not the best thing ever, but it's more than usable. I wouldn't do a setup and intonation with it unless I was desperate or had nothing better, but beyond that....
I will say one thing though that I learned a long time ago if you are having trouble with a tuner that seems like it just won't settle down. First use the neck pickup by itself and then roll the tone all the way off so that it sounds nice and muddy. What this does is eliminate a lot of the harmonic content (the same stuff that makes a lot of those pickups sound so great). If you've got a lot of extra "character" in there it can confuse the tuner. But if you send a nice strong, fundamental frequency it works a lot better.
Try it. It's not my tip, I stole it somewhere and can't remember or I'd give credit.
Old 10-18-2011, 04:28 AM
zedhed's Avatar
zedhed zedhed is offline
Dude there's always the good ol fashioned way of tuning...you know those things on each side of your head, takes about 30 seconds
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 08:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 07:07 PM
Hook up tuner to digi 002 or eleven rack crashhak Eleven Rack 7 11-26-2011 02:34 AM
Eleven TDM Tuner Siegfried Meier Pro Tools TDM Systems (Mac) 1 07-08-2011 09:58 PM
Eleven Tuner? HD2 Virtual Instruments 13 12-31-2010 08:47 PM
