Old 09-17-2011, 11:45 PM
Jd0g33 Jd0g33 is offline
Default Where is this white noise coming from(11r+m5)
First i have the fx loop bypassed and it has a normal amount of noise when not playing but when i turn the fx loop on and just have the m5 on dsp bypass it is way noiser(8 seconds in the clip) and ive gotten multiple complaints from soundmen. Is this ground loop hum or just natural running two digital devices at once.
http://soundcloud.com/lundyjb/white-noise-8
Old 09-18-2011, 12:50 AM
Default Re: Where is this white noise coming from(11r+m5)
That link does not work.
Also what happens if you go out the FX loop and the loop is just a cable?
Without hearing it what effect in the M5 are you going after and are you sure there is not an effect something build into the Eleven Rack that would get you where you want to go?
What do you gave the Eleven Rack loop level set to rack or stompbox? (try both to see what sounds better).
Darryl
Old 09-18-2011, 01:26 AM
Random Dude Random Dude is offline
I know that I tried using an M5 in my FX loop in stereo and it was just noisey as all get out. I'm pretty sure that in my case it was from the cables since they were unbalanced and I have noise issues in this room to begin with. If you've got long runs I wouldn't be surprised if that wasn't at least part of the cause.
It could be a ground loop if both units are getting power from different outlets.
Old 09-18-2011, 06:59 AM
TFord TFord is offline
Are you reffering to noise or hum? In case of noise: the loop of the 11R is very noisy when putting it in front of the amp model. Putting it after the amp model is pretty much noiseless.
Old 09-19-2011, 12:58 PM
fly_with_v fly_with_v is offline
This is my conclusion as well. And it sucks. I use a Droptune for practice and I just put it before the 11R. Way too noisy in the loop and it needs to be infront of the amp.
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini Bigpit Windows 1 09-09-2013 10:26 AM
Burst of noise (not necessarily white noise) at the end of clips Swarf macOS 9 09-20-2012 09:55 AM
Static noise (aka White noise ) During playback. =/ PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-23-2010 05:06 PM
white noise coming from mbox when spdif selected djaikon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-23-2004 10:34 AM
Pink noise vs. White noise kcarter Tips & Tricks 9 08-29-2001 11:42 PM
