Old 10-12-2014, 10:21 PM
Mike496's Avatar
Mike496 Mike496 is offline
Default S3L Virtual Sound Check Issue
Hey everyone, I'm having a virtual sound check issue. I was able to record to Protools fine using the s3l system but when i switch to playback from Protools I get a strange digital noise and a slight playback lag. I recorded to PT 11.2.1 on a 2011 MBP running OS 10.8.5 via CAT5e. Also my Playback Engine says E3 Engine and not Avid AVB64 as the manual states...
Thanks for any help you can provide!
Old 10-13-2014, 03:30 AM
Soundrambo Soundrambo is offline
Default Re: S3L Virtual Sound Check Issue
Try using PT 11.
Avid is recomending PT 11 for S3L and PT 10 for use with other VENUE consoles.
Old 10-13-2014, 07:03 AM
Mike496's Avatar
Originally Posted by Soundrambo View Post
Try using PT 11.
Hi Soundrambo,thank you for your reply. I'm on 11, updated my post to include the Protools version. Thank you!
Old 10-13-2014, 11:19 PM
Mike496's Avatar
In case anyone see this and has a similar problem, I solved my issue. After working with Avid support earlier today we decided it was best to update my OS to 10.9. The playback for virtual sound check is now working after the update and reinstall. I also had to enable the E3 engine in the Audio MIDI Setup app. I did this by going to Audio MIDI Setup > Window > Network Device Browser.
Old 10-14-2014, 03:07 AM
LanceK LanceK is offline
Does it only give you the amount of channels you have stageboxes for? In other words, if I have 1 stagebox can I still get more inputs from Pro Tools in Virtual Soundcheck mode?
System Details: Macbook Pro 17"
OS 10.7.5
PT 10.0
8 gig ram
FW Drives (Multiple)
eSATA Drives (Multiple)
[email protected]
Old 10-14-2014, 02:20 PM
Amplitude Amplitude is offline
Always 64 AVB In/Out, no matter how many S16 you have connected.
Virtual Sound Check Webinar question David Colella VENUE Live Sound Systems 0 08-13-2012 12:44 PM
Virtual Sound Check - PT LE & Firewire dmxproductions VENUE Live Sound Systems 3 09-17-2010 07:31 PM
Virtual Sound Check Question Lee Lundgren VENUE Live Sound Systems 14 09-11-2010 09:30 PM
Virtual Sound Check SC48 J2sound VENUE Live Sound Systems 2 07-24-2009 08:16 AM
The best way to use virtual sound check kalunga VENUE Live Sound Systems 5 08-08-2007 12:07 AM
