Old 05-14-2018, 12:01 AM
johnbarnesiii johnbarnesiii is offline
Default Digital Piano No Longer Registering in PT?
Hi guys,
I have a Yamaha P-105 digital piano connected to my Pro Tools system on a Mac via USB cable. Suddenly it is not reading on my DAW. Here are my DAW specs:
• PT 12.5.1
• Mac OS 10.13.4 (High Sierra)
•*Apogee Duet interface
• Yamaha P-105 digital piano connected vis USB
Please note that everything has been working for many many months with no issues with the keyboard connection. I did not do anything differently as far as I know. Just when I fired up the rig tonight, the keyboard no longer reading.
I took a screen shot of the Audio setup within PT. I also tried restarting my Mac, as well as unplugging and replugging the USB cable, to no avail.
Any suggestions?
Thanks!
File Type: jpg Screen Shot 2018-05-13 at 11.47.11 PM.jpg (35.1 KB, 0 views)
Old 05-14-2018, 12:42 AM
Stig Eliassen's Avatar
Default Re: Digital Piano No Longer Registering in PT?
Have you tried a factory reset?
Old 05-14-2018, 06:41 AM
amagras amagras is offline
Go to Setup/Preferences/MIDI and check if Default Thru Instrument is set to Follows First Selected MIDI Track
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-14-2018, 08:34 AM
BScout BScout is offline
It's greyed out in Audio MIDI setup.
This isn't a Pro Tools problem. This is the keyboard not being seen by the computer (macOS.) Once it is seen again, it'll work with Pro Tools again.
Try a different USB cable.
Is the keyboard powered on/do you see power?
Try a different usb port on your computer.
Old 05-14-2018, 10:23 PM
Thank you, you were correct. It was an issue with the USB hub in which I have the digital piano plugged. I shut down my computer, power cycled the hub, plugged the DP into a different USB port on the hub, turned everything back on again and voila... back to normal. Thanks kindly for the help!
New Digital Piano, New Mac, a few questions enigma2024 FireWire & USB Audio Interfaces (Mac) 0 03-31-2014 05:31 PM
Using VSTi's with a digital piano Maxabillion macOS 1 10-02-2013 10:37 AM
Digital Piano.... xlrsound General Discussion 2 05-15-2007 01:56 PM
Digital Piano Shootout Andy R Virtual Instruments 0 06-09-2006 01:26 PM
The Very Best Digital Piano azure sky Tips & Tricks 9 03-05-2001 08:43 AM
