Old 04-16-2021, 11:19 AM
weezul weezul is offline
Default Bounces not the correct length
As stated. Mojave, 2021.3.1... highlighting a time selection and exporting... I'm getting bounces of the entire session.... and then a few extra minutes on the end.
Anyone else?
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 04-16-2021, 12:41 PM
paul_g's Avatar
paul_g paul_g is offline
Default Re: Bounces not the correct length.
Hi Liam, no issues here, just grabbed a session (where the length was already selected), bounced to both .wav and .mp3, no issues at all.
Try trashing prefs?
p.s. - in your signature block, it will be helpful to have your system config listed. Others may have more info based upon your specific config :)
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 04-16-2021, 01:09 PM
Thanks for checking Paul. I've found it's happening with old sessions that I opened from before 2021, but on a fresh session today it exported correctly. Will trash prefs
Old 04-16-2021, 05:30 PM
matchmix matchmix is offline
IF you selecting the section you want to bounce in the time line try selecting in the audio window and make sure the timeline audio link is turned "on" I've seen that setting change when opening sessions that did not have it on.
Drawn MIDI note length only staccato notes, regardless of note length kingofallwookies Pro Tools 11 2 02-07-2014 07:10 AM
ADC and bounces EricWillhelm Pro Tools 10 3 12-20-2013 09:44 AM
Copied region length auto-adjust to paste location length? greglawrence Tips & Tricks 4 10-23-2011 12:46 PM
7.3 on 10.4.9 bounces once, then nothing DjA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-18-2007 07:53 AM
Correct show length dBgogogo Post - Surround - Video 5 08-25-2002 09:29 PM
