Re: Files not gone after select unused+clear
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Save copy in and reinstall pro Tools?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
It hasn't worked correctly since PT7 I think. Make sure you delete the undo history and then do it again and it usually clears everything.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
Exactly this. I used to close and re-open the session, but now I just create and then immediately delete a track. That's the only way I've found to be able to clear the undo queue (without reaching for the mouse that is - someone may have a better shortcut keyboard method...?)
Wierd that didnt work for you all well friends . I always use this steps . Consolidate > select unused > clear selected > delete . Always work as expected for me :-/ !
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
CLIPS > Select > Unused is unchanged after running Delete Unused | SigFriedChicken | macOS | 1 | 07-02-2017 09:25 PM |
Select Unused Files not really efficient... | Nese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-02-2006 12:22 PM |
Can't select unused regions/files | Hume | Pro Tools TDM Systems (Mac) | 1 | 05-09-2006 11:08 PM |
Select unused reagons clear selected deleted used | Mark 66 | Pro Tools TDM Systems (Mac) | 5 | 04-26-2004 03:51 PM |
select unused will delete unused | jimlongo | Pro Tools TDM Systems (Mac) | 4 | 04-04-2001 06:39 AM |
