  #21
Old 02-26-2019, 07:38 AM
D'Animation D'Animation is offline
Default Re: Sample accurate digilink interfaces in 2019?
Originally Posted by JFreak View Post
Makes sense. Then there is nothing that can be done, right? If a 3rd party interface would be faster than Avid's they could match the RTL by slowing it down
Yeah, nothing can fix a longer delay unfortunately. Think its Apogee that go into quite a bit of detail on their thinking behind the latency - their A/D and D/A times are different so they could make the conversion quality up to the standard they wanted it to be (takes a little longer than Avid) and then refined the other side of the process to compensate - they add up the same as the HD i/o roundtrip so it all balances out. Seemed like a clever way of doing it
  #22
Old 02-26-2019, 09:33 AM
LukeHoward LukeHoward is offline
Once Avid introduced the DigiLink license, they pretty much admitted that third party products exist. So it's a pity they don't have a plugin API (well, potentially just a configuration file format) that allows third parties to identify their interfaces and report the conversion delays and I/O names.
https://lukehoward.com/
  #23
Old 02-26-2019, 11:03 AM
YYR123's Avatar
YYR123 YYR123 is offline
If you use 3rd party iO’s that would be awesome
Daniel
  #24
Old 02-26-2019, 01:00 PM
LDS LDS is offline
Originally Posted by JCBigler View Post
I mean, this is only relevant if you are sending a signal outside the box, from one interface to another, right? If everything stays inside the Protools mix engine, it doesn't really apply, right?
It is only relevant if you are using a single interface that doesn't replicate the latency of a Digidesign or Avid model, and you try and add an analogue insert into your mix. When you do so, the problem is akin to a plugin that reports the wrong latency back to the mix engine, which in turn means automatic delay compensation offsets the audio by the wrong amount.
The problem is essentially mix engine based, as digilink interfaces have no way of reporting their latency back to Pro Tools and it has the potential to turn an expensive interface into a cheap, busted plugin.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
  #25
Old 02-27-2019, 05:16 AM
True, that would be nice. Or at the very least, if they licence the digilink connector to a manufacturer they at least put a restriction that the internal hardware must exactly emulate the Hd i/o
  #26
Old 02-27-2019, 05:48 AM
Yeah, although I don't know if they ever really licensed it – I think the third parties just reverse-engineered it. But maybe this has changed with the introduction of the license.
  #27
Old 01-01-2020, 09:38 PM
khoop2112 khoop2112 is offline
If I remember correctly from Focusrite support & other user reports their converter delay is longer than the Avid i/o
I am demoing a Red 16 Line - love how it sounds and the connectivity is AMAZING. But it is not at all sample accurate the way the HD I/O was.
When recording simultaneously into the HD I/O and Red 16 line (at 44.1k), the Red is 15 samples LATER than the HD I/O, with the delay compensation on. When it's off, the red is 5 samples later than the HD I/O.
Obviously similar issues when using the Red in insert mode, and although you can compensate in the I/O setup for HW inserts, it changes based on the SR. My tests showed 26 sample latency @ 44.1, 28 samples @ 96k. So really no chance to use outboard analog gear in parallel with the Red 16 line.
  #28
Old 01-02-2020, 12:59 AM
syMPh syMPh is offline
Burl is (mostly). Their older BAD4 cards are a bit slower and don't do AVID delay comp sample accurately. All other cards can be jumpered to be either AVID delay compensated or their native latency which is much faster. Documentation on their website provides quick starts with all info needed on each individual card.
System Details
  #29
Old 06-15-2021, 05:10 PM
SaschaP SaschaP is offline
Does anyone know if the new Focusrite Red 8 Line interface is sample accurate? It is the perfect amount of i/o and connectivity for me.
  #30
Old 01-23-2022, 05:09 PM
jerrybarnesbass jerrybarnesbass is offline
This is Great info !
Im thinking's of getting a Avid interface and plugin in My Symphony MkII via AES
(My HDX card is in a chassis connected vis digilink to the Symphony MK II right now )
MY question is would Protools see the Symphony as 8 more channels of in and out and would the delay compensation work with both interfaces ( the Avid interface being the main )
Right now I cant do analogue parallel hardware comp ( for example )
with my Symphony and PT
Thanks Jerry
List of third-party Digilink interfaces? Matt Hepworth Pro Tools HDX & HD Native Systems (Mac) 14 11-19-2023 02:49 PM
Interfaces under Inputs say DigiLink N/A. What's going on? [solved] Focuret Pro Tools HDX & HD Native Systems (Mac) 0 03-17-2018 10:23 AM
Sample accurate recording derekvh Post - Surround - Video 2 02-03-2014 08:55 PM
AC3, is it Sample Accurate? minister Post - Surround - Video 13 03-13-2007 10:57 AM
Sample accurate midi? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-09-2005 11:48 PM
