skipping during playback
I've always had this problem since i installed pro tools on my comp, but now it's getting to frustrationg and now and gonna ask for some help to finally fix it completely once and for all.when i finish bounce down a track i like to listen to the track through windows media player or quicktime or even i tunes to check for any problems withing the bouced files.but i cannot do that because when i load a file throough those programs,each program has a problem. first when i play back through wmp it skips like crazy,when i try quicktime there a loud static sound and it also skips, and finally i tunes just skips as much as wmp. i forced to do either two things. transfer it to my usb and listen to the track on my laptop, or open up pro tools and under import audio i find the file and listen to it there. why does this happen. when i stream music through the internet it plays fine,but when i use my programs im screwed. i cannot even play cd's on my pro tools comp i have to open up pro tools and listen to my cd's there otherwise it'll skip with other programs.It's so embarasing when someone want's me to listen to a cd and i have to open up pt and listen to it there,or hook the laptop up to my monitors just to hear 1 track!!!
here's my set-up pt7.3cs4 amd athlon 64 dual 2.0 ghz 3gb ram 250 gig hd/which i don't use windows xp media center edition sp2 PLEASE HELP I AM DESPERITE |
Re: skipping during playback
have you ever changed any settings in WMP,maybe in the past that you have forgotten about?
which version of quicktime do you have installed?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
i have i tunes 7.3.2, quicktime 7.2, and wmp version 11. every since i installed pro tools i had the problem. when i uninstalled to upgrade to 7.3 all the programs worked fine, but once i put in 7.3 same thing. there a problem with the drivers you think not compatible with those programs?? and also i used the digi mme helper to add the programs to the soundcard.
i think there is problems running protools with windows media center. i will try and find which qt i am using
Playback Skipping | thadjtig1 | Windows | 1 | 04-11-2013 05:11 AM |
pt9 on win 7 32 bit skipping noises during playback | Ibester | Windows | 2 | 01-09-2011 07:03 PM |
Skipping during playback | ian Bourgal | General Discussion | 1 | 07-05-2009 11:54 AM |
Playback Skipping While Editing in 7.4 | BigMeany | Pro Tools M-Powered (Mac) | 4 | 12-22-2007 09:11 PM |
Skipping during playback | JAH FYAH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-25-2007 02:00 PM |
