No sound during playback after crash and reinstall
I can't find this specific issue on the forum search, so I am seeking some help here....getting desperate at that!
I am still using PT LE 7.4 on a Windows XP platform (ancient, I know....)..going to upgrade soon, but I really need to get up and running. My hard drive crashed and was repaired, and PT reinstalled, but now when I pull up one of the files I was working on in the recent past I get no sound during playback, although the finished WAV files play fine on Windows Media Player. Is this a driver issue, or, if I need to reinstall PT, will I lose my saved songs? My hardware was adequate enough to run PT fine prior to the crash, so I won't list everything. I feel it's a driver issue, perhaps, but I just don't know. Can I still get drivers for 7.4? Any help on this is greatly appreciated. |
Re: No sound during playback after crash and reinstall
Try resetting your I/O to default in Setup.
Cheers,
BTW, you won't lose any of your recorded songs when/if you ever un-install, re-install PT not least of all because you are recording them to a separate drive than C: right?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
In all versions of Pro Tools BEFORE 9, the drivers are part of the installer. Did you run the installer as per the instructions, or did you forget about that and let Windows do it automatically(like most other programs)? What the Weed offered is certainly a possible solution too. Also, since you are fussing with the setup(and we have no idea what it consists of), you might re-trace and double check all your cabling too(its pretty easy to mis-patch outputs)
Actually, I had my neighborhood tech do it for me, so I'll have to double-check the I/O in setup and then check the drivers, which I'm leaning strongly towards being the issue..........I was able to play older recordings in WMP, so I know my cabling/connections should nopt be the issue, but you know how that goes- I will disconnect and reconnect everything and see what happens when I do these things.
Thanks for the input all! |
crash on playback | travista00 | Pro Tools TDM Systems (Mac) | 2 | 05-16-2009 01:06 AM |
PT Playback crash | artemis prime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-04-2007 02:57 PM |
Static sound after stoping playback/Frequent crash | briancometa | Pro Tools TDM Systems (Mac) | 1 | 10-17-2005 08:05 PM |
After PTLE reinstall my hard drive "is not an audio playback volume" | spudnik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-11-2003 10:36 AM |
Pro Tools LE 5.2 - Playback Crash | pw9r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2003 12:58 AM |
