CPU (RTAS) meter bouncing around
Is the CPU(RTAS) meter in the system usage window supposed to jump around wildly? It seems to regularly jump from a number in the teens up to 30%, 40% etc. I've noticed this on several of the systems I've worked on.
-Richard
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5 www.TakomaMedia.com |
Re: CPU (RTAS) meter bouncing around
The answer might depend on what plug-ins you are using and the engine playback buffer size. For each playback buffer, all the plug-ins are given time to do their processing. If a plug-in does irregular amounts of processing for each buffer, the CPU usage will vary. A common example is convolution reverb which has to perform FFT processing at irregular intervals. Other examples are our Neyrinck Dolby Digital, Dolby E, and DTS decoding plug-ins which decode blocks of data at intervals that are different than the playback engine buffer sizes. Typically, increasing the playback engine buffer size tends to smooth out the CPU usage.
Thanks Paul! That was it. I just shut off a Convolution reverb that is iin my template and the meter settled down.
-Richard
CPU (RTAS) Meter | yarrick19 | Pro Tools 9 | 5 | 12-08-2010 02:23 PM |
RTAS CPU meter reading 107% one processor selected! | crizdee | Pro Tools TDM Systems (Mac) | 22 | 11-12-2009 10:04 AM |
-9128 error with 45% RTAS meter | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 02-26-2009 03:54 PM |
RTAS Meter Creeping up when stopped | BrownMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-14-2008 09:32 AM |
BF Free plugins, RTAS only Meter Bridge????? | McMasters | Pro Tools TDM Systems (Mac) | 4 | 03-02-2004 02:17 PM |
