Old 06-28-2006, 12:36 PM
blue demon blue demon is offline
Default Just updated ITunes and Quicktime, now have issues
I'm OS 10.3.9 running LE 6.4. Just updated to Quictime 7.1.1 and iTunes 6.04. Of course now Pro Tools can't see the hardware for whatever weird reason. I tried to find a re-installer of the older versions on Apples website but could only find re-installers for older existing versions of quicktime. I have a project coming in today, and need to start working on it. Anyone know what I should do?
Film in America.
Old 06-28-2006, 12:57 PM
stormmusic stormmusic is offline
Default Re: Just updated ITunes and Quicktime, now have issues
you have to re install QT 7--not the updated one--i think it's 7.0
Old 06-28-2006, 12:58 PM
CCH CCH is offline
"Of course now Pro Tools can't see the hardware for whatever weird reason. "
What hardware are you referring to? Digidesign hardware, or some sort of Firewire Capture device like the Canopus ADVC100 or 110?
I am running 10.3.9 with Pro Tools 6.9 on an HD2 system, and after installing Quicktime 7.1.1 I wasn't able to output a DV stream in Pro Tools through my ADVC110 firewire device. I had to remove the old Quicktime version receipts from my system. Here is a link on how to do this. This link is in regards to Final Cut Pro software, but it is a similar issue and should work to restore connectivity between Pro Tools and your firewire video output device.
http://docs.info.apple.com/article.html?artnum=301852
In my case, all I did was remove the receipts for older versions of Quicktime and I was able to resolve the problem.
This is assuming of course that this is the problem you've encountered.
Regards,
CCH
Old 06-28-2006, 10:09 PM
I meant that it's not seeing the 002R hardware.
-Dave
Film in America.
Old 06-28-2006, 10:13 PM
The problem is that none of the old re-installers will re-install with 7.1.1 already there. Ii have Quicktime Pro, and I'm worried that if I just trash it, and start over I'll lose quicktime pro.
Film in America.
Old 06-28-2006, 10:36 PM
Noiz2 Noiz2 is offline
It's not too helpful but I had a similar problem and had to reformat my HD and restore from a back up to go back. If I hadn't had a current backup from just before the install I would have been screwed. There is a site that keeps old installers available but I don't think it will do you any good because of the "can't go back" style of the upgrade. I don't think you will lose the Pro, though you may have to reenter the serial #. It should work for the version of QT that you bought.
Good Luck
www.scottkouesound.com
SK
Old 07-02-2006, 11:33 AM
i complained to DIGI and someone sent me a QT7.1.1 UNinstaller--after you run that you just re-install QT7.0--but you do have re-enter your name/auth code for QT pro
if i can find the link on one mf my backup drives i'll send it to you
HTML code is On
Updated Quicktime and PT won't open rgdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-16-2007 08:43 PM
Just updated iTunes and Quicktime, now have issues blue demon General Discussion 7 06-28-2006 11:08 PM
Just updated to Itunes 6 and now i can not open ezrambox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-28-2006 01:07 PM
Mbox and PT 6.4 issues with Quicktime and Itunes Bugs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-02-2005 10:23 AM
Any known issues w/ Quicktime 6.5 and iTunes 4.2 ? auxsend1 Pro Tools TDM Systems (Mac) 0 01-09-2004 11:01 AM
