Old 04-07-2005, 01:32 PM
trimix trimix is offline
Default FireWire 1814/ PT questions
Just read the 1814 manual which has prompted some questions. It seems the 18 input/ 14 output statement on Digi's hardware comparison chart is a bit of a misnomer as you have to select either ADAT or SPDIF I/O, not both. Has anybody tried one of these with the PT demo yet?
- Is the ADAT SMUX I/O available at 96k in PT?
- Can you use multiple M-Audio interfaces with PT?
- Does the hardware-based monitoring software run smoothly alongside PT?
I see the 1814 comes bundled with Reason Adapted and Delta Live, I wonder how these differ from the Digidesign Editions...
Old 04-07-2005, 10:54 PM
sunnywheat sunnywheat is offline
Default Re: FireWire 1814/ PT questions
how many 1/4 inch inputs are there? can i hook up the octane and run 16 tracks or whats the deal thanks for any help
Old 04-08-2005, 07:00 AM
tomdrums tomdrums is offline
Can the Firewire 18/14 connect to pc with a 4pin firewire port using a DC power adapter for power?
Or does it always require a 6pin firewire port on pc regardless of being powered by firewire buss or DC power adapter?
Old 04-08-2005, 07:21 AM
There are eight 1/4" TS unbalanced -10db analog inputs, the first two of which can be switched to use the front panel mic pre/ DIs if you wish. You can patch another 8 channels in via the adat optical input, so yes, 16 inputs total capacity. HTH
Old 04-08-2005, 07:24 AM
It works with 4 pin 1394 ports, you just have to use the included 12V DC power adapter instead of bus power.
Old 04-09-2005, 02:58 AM
Thanks, good to know the 18/14 can go with a laptop with only a four pin firewire port.
No other way than the Firewire 1814? shultzee13 Pro Tools M-Powered (Win) 4 08-12-2008 01:54 PM
HELP! Firewire 1814 with M-powered reezy Pro Tools M-Powered (Mac) 5 07-12-2007 07:22 PM
Mac Pro 2.66, Firewire 1814, 10.4.7 Imagine Pro Tools M-Powered (Mac) 7 09-21-2006 11:13 AM
Firewire 1814 Bill Pillmore Pro Tools M-Powered (Mac) 0 11-08-2005 05:38 PM
ATTN:1814 Owners..I have a few questions dversion Pro Tools M-Powered (Mac) 4 07-02-2005 07:25 AM
