Old 03-09-2006, 08:51 PM
Eddie D Eddie D is offline
Default I cant hear sound while previewin using AudioSuite
Hey Fellas,
The title says it all. For some reason when using AudioSuite I cannot preview how it will sound. I get no sound at all during preview. Hopefully someone can help me figure this one out.
Thanks
Eddie
Who Ever said this would be Easy!!!
www.myspace.com/sightthrusound
Old 03-09-2006, 09:37 PM
spkguitar's Avatar
Default Re: I cant hear sound while previewin using AudioS
In I/O setups, what do you have listed for your "Audition Path"? Is it an I/O that you are monitoring out of?
Old 03-09-2006, 10:45 PM
Hey Spkguitar,
Im monitoring out spidf, but its not in the audition path to select? Makes sense that should be spidf just gotta to get that option in the audition path.
I will keep trying to figure it out, and checking back here also if you chime in.
thanks for clueing me in. Right now the only options I have are the Analog 1/2 3/4 5/6 7/8
Eddie
Old 03-09-2006, 11:15 PM
Hey Spkguitar,
Eddie
Ok I give,,,,,Im not sure how to get spdif in the audition path. Could someone explain how to do this, please.
Thanks
Eddie
Old 03-09-2006, 11:32 PM
spkguitar's Avatar
Actually, if I remember correctly, this isn't possible right now.
I found a workaround in an older thread, but I'm not sure if this works or not.
>The default paths do not include S/PDIF but you can change your I/O Setup
> to allow for S/PDIF as an audition path. Open the I/O Setup and click on
> the Output tab. Click Default in the lower right hand side of the window.
> Choose an analog output path the switch to S/PDIF (you may want to use
> 7-8). In the Output window uncheck that path so it's inactive. Locate the L
> and R in the grid that corresponds to S/PDIF and drag them over to the left
> to use that path. Now you will be able to select S/PDIF as an audition path
> at the expense of a pair of analog outputs.
Old 03-09-2006, 11:40 PM
Ok cool, I will try on 1/2 because my headphone mix is going out 5,6,7,8. I will let ya know if this works.
Thanks
Old 03-10-2006, 12:08 AM
Looks like a no go, trying it that way.
Its funny because I was at a digidesign user group tonight and a rep from digi was there. When I explained what my problem was, he had no clue and said I would probably have to reinstall. I was like ummmm nooo that is not the problem. I went on futher to explain using a comparison to my problem (when using spdif it doesnt allow windows media player to flow thru pt and Im thinking this maybe the same for AudioSuite). Well it looks like this one wont be solved unless I run my analog 1/2 outs thru the central station.
When I inactivate analog 1/2 and put spdif on 1/2, I get no sound from my session but it does show up in the audition path. It was worth a try, for now I will just deal with it unless you or someone else can come up with some other ideals.
thanks
Eddie
Old 03-13-2006, 09:33 AM
chanlon25 chanlon25 is offline
Funny - I was going to post the same problem this morning when I saw this.
So far, I can't find a way to audition and have the SPDIF outs in my session. Anyone doing this in LE?
I would hate to have to sacrifice a pair of analog outs solely for auditioning!!!
Any thoughts would be appreciated!
-C
Can't hear audiosuite plugins szac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-03-2005 07:35 AM
AudioSuite Preview - How to hear both channels? tkoyn Digidesign Hardware & Software 3 08-01-2003 03:55 PM
AudioSuite Preview - How to hear both channels? tkoyn Digidesign Hardware & Software 0 07-24-2003 07:06 AM
AudioSuite Preview - How to hear both channels? tkoyn General Discussion 0 07-24-2003 07:05 AM
CANNOT HEAR THE "PREVIEW"OF AUDIOSUITE PLUG-INS Kingsta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-07-2002 10:39 AM
