Old 05-27-2015, 04:00 AM
Davoetta Davoetta is offline
Default Problem with User Layer Presets
Hi!
Last weekand i had an problem with the user layer presets.
I made an preset with my "Entry Music-Fader" (USB Return on an Stereochannel) on the user layer.
This Stereo Channel is the last Input Channel called "MP3" (63+64) - Channels 50-62 are blank and unused.
So far no problem - i assigned the MP3 channel to the far right channel on my user layer - so far so good.
Then i saved the preset - then i recalled the "standard" snapshot and wanted to recall the user layer for the entry music but it did not recall the user layer right instead of the MP3 channel that i saved before there was an FX Return on it.
So - assigned it again - saved it again - same problem.
Looks like this is only happening with my MP3 channel - is it because its the last input channel on the board???
Can anyone try this please?
Old 05-27-2015, 04:01 PM
Karel Noon Karel Noon is offline
Default
is there some other difference in the file? like more linked channels or other differences in the layout? something set to recall safe? i had that problem with the PT inputs
can you send the showfile via email then i would check it with my system.
Old 05-27-2015, 10:40 PM
Default
Hallo Karel!
No - there was nothing recall-safe as far as i have seen.
Its weird - cause in the Offline Software it works as it should.
Would be nice if u could have a look into it - maybe u find something...
Old 05-29-2015, 12:18 PM
Mike Z's Avatar
Mike Z Mike Z is offline
Default
Thanks for reporting this Davoetta.
We were able to reproduce the issue and will look to include a fix in the next release.
Avid Live Sound Support
Old 05-29-2015, 12:22 PM
Valentyn Valentyn is offline
Default
See that. Thank you for reporting.
Old 05-29-2015, 02:54 PM
Amplitude Amplitude is offline
Default
haha. i had the same issue and thought it was just me
Old 05-30-2015, 04:21 AM
Default
Thanks everyone for looking into it.
Good to know it was not my fault.
Hope to see a new fixed version soon.
Old 05-30-2015, 04:25 AM
Default
I'd suggest not using user layout presets until the issue is fixed.
Snapshots with layouts provide an alternative way to achieve the same result, especially when combined with "Import Snapshots" feature.
Old 05-30-2015, 09:31 AM
Default
I know - but i`d like to see this issue fixed and that it works as it should.
Old 07-09-2015, 11:13 AM
Default Re: Problem with User Layer Presets
Davoetta, could you please check 4.5.2 and confirm the issue fixed there?
User Presets & Plugins -- PROBLEM mikevarela Post - Surround - Video 0 06-13-2013 12:46 PM
user presets without PT prkaye Eleven Rack 5 03-27-2011 12:51 PM
AIR User Presets Reddit fenderrocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-24-2009 02:57 PM
Eleven User Presets? AndyJCP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-02-2009 06:46 PM
d-fx user presets coaster Pro Tools TDM Systems (Mac) 0 10-19-1999 05:19 PM
