Old 02-07-2013, 11:26 AM
shotgunndunn shotgunndunn is offline
Default Reverb on drums is mostly in the right channel...
Sup guys?
I have a mix I'm working on and I have the Waves TrueVern plugin on an aux buss with all drum track with sends to the bus the is feeding the aux track with the verb on it.
I hear the reverberated sound fine. However, it is sounding like it is heavily panned to the right. All my sends feeding this bus are mono and panned center. The overhead track is stereo and is panned hard LR.
What could be causing his? It's not a monitoring issue since all other mix elements are properly imaged. It's just my reverb sends to a buss and then to an aux track with the verb plugin. FWIW, it does this with every verb plugin. However, it does not do this to my parallel drum crush bus.
Any tips?
Old 02-07-2013, 11:28 AM
browniespeaks browniespeaks is offline
Default Re: Reverb on drums is mostly in the right channel...
what do the meters say? you could put a metering plug before and after the verb to see what its getting. Could be destructive interference from bad phase alignment at the recording stage. One channel could just be louder than the other (not uncommon in st recording)
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 02-07-2013, 11:29 AM
Also, I just bypassed the Trueverb plugin and the sound is panned center as it should be. I guess it's the plugin. How do I solve this?
Old 02-07-2013, 11:31 AM
After the verb, with the verb engaged the meter show about a 5-6dB difference with the left sound being louder.
Old 02-07-2013, 11:34 AM
Same meter plugin, but before the verb, L and R are dead even. Not a recording issue. It's this TrueVerb. My Dverb doesn't do this neither does my Waves RVerb. Only the Waves TrueVerb.
Old 02-07-2013, 11:38 AM
Hmmm...re-install Waves? Try loading some presets to see if all act the same?
Old 02-07-2013, 11:44 AM
Top Jimmy's Avatar
Did you manage to open TrueVerb as multi-mono rather than multichannel? When multi-mono, the sides can be unlinked.
Buttdialed by me & Tapatalk
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-07-2013, 11:48 AM
I guess I'll try that. I'm pretty sure I can DL just the one plugin trough my waves account.
On another note, is your last name Odum? As in Alby Odum from Daniel's Window?
No. It's multichannel.
Old 02-07-2013, 02:50 PM
P,B,S P,B,S is offline
How is the send panned. the panning on sends could cause that problem.
Some plugs let you adjust the L/R balance check that is my opinion but panning could do that as well.
Gated Reverb on Drums Legion6789 Pro Tools 9 4 10-08-2011 02:05 PM
Delay/Reverb: On the Channel or Bused to an Aux Channel. mbyeates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-26-2010 04:55 PM
Reverb for Drums and El Bass DonaldM Tips & Tricks 12 08-02-2010 10:06 AM
Reverb and Compression on Drums drumkid Tips & Tricks 5 06-13-2005 02:34 AM
Reverb on Drums? DoneDigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-22-2004 10:27 PM
