  #161
Old 06-17-2009, 12:00 PM
TOM@METRO's Avatar
Default Re: Play/Pause Issue Resolved - Maybe? Try This.
I could not log on as an UPPER LEVEL administrator until I used Tweak UI>Logon. Way earlier in this thread there is reference to this. I had an Administrator account but had to use Power Toys Tweak UI to get an upper level Administrator account.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #162
Old 06-17-2009, 12:05 PM
Banana Banana is offline
So the conclusion is basically that the "login as admin" workaround is not possible for XP Home users. The unchecking of the box is as far as it can go, and that one has lost its effect for me. Annoying as hell.
  #163
Old 06-17-2009, 12:09 PM
mykhal c's Avatar
mykhal c mykhal c is offline
here is a link, well, i'm not sure if it helps out or not. and i could not 'fully' test it out. i'm not in my studio right now, where i run XP Home, but do NOT have the PPI either. but on my old P4 rig which has PTLE still installed and runs XP Home, i at least wanted to see if the instructions shed any light. i did not see an Administrator account, only my actually accts with admin privileges. so maybe someone can look into it further that has their hardware connected and see if anythin' gives....
http://support.microsoft.com/kb/305780
hopin' it can help
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #164
Old 06-17-2009, 12:11 PM
TOM@METRO's Avatar
I would still try the Tweak UI solution.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #165
Old 06-17-2009, 01:54 PM
I already did, as stated earlier in this topic. No dice.
  #166
Old 06-17-2009, 04:45 PM
DigiTechSupt's Avatar
I'm hoping we can get a bit more info from anyone experiencing this issue. If you can answer the following questions, it would help us narrow down all the iterations of this problem.
1. Do you have Error Suppression turned on? If so, disable it - do you now get errors and, if so, what are the error numbers.
2. If you get this problem a lot, can you do a quick-ish test and press play and just let it sit - does it eventually start to play? You shouldn't need to wait more than 6 minutes at 48k or 3 minutes at 96k to determine this.
3. Which Digi HW are you using?
Thanks!
Avid Audio Tech Support
Support FAQ
  #167
Old 06-20-2009, 09:40 PM
jeam25's Avatar
jeam25 jeam25 is offline
Nope ! error supression is disable !
003 mixer
- Jesus Alvarado -
Keep the volume UP !
  #168
Old 06-20-2009, 09:42 PM
jeam25's Avatar
I cant beleive they didnt resolve this YET !!
- Jesus Alvarado -
Pro Tools 11 Play-Pause Issue ProdGawd Windows 7 12-12-2013 06:22 PM
PLAY / PAUSE - Issue ... Once More !!! Zergei Pro Tools M-Powered (Win) 2 12-27-2009 12:50 PM
Play Pause issue fixed????? gwattaloopy1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-17-2009 03:35 AM
Some info on the Play Pause Issue Fastermouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-31-2009 06:18 PM
play/pause/cursor issue manyrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-07-2007 11:38 AM
