How\'s Windows ME working for you?
Just wondering how Windows ME is working for everyone. I'm going to do a fresh install of the OS and I'm thinking of going to ME (been using 98SE). I've also heard that it is crucial to go to windowsupdates.com and opitmize this OS. Has anyone else heard of this? My poor system drive is loaded with crap. I can't even shut PT down, but man it sure runs better than ever. Someone posted an article from Tascam on the DUC on how to optimize your computer and it really helped out my already kick butt system. Check it out. Thanks guys.
Don't be a puppet on strings! |
Re: How\'s Windows ME working for you?
~Cheers~
|OS 10.2.8|80gb ATA100|120gb ATA100| |Mac|FW800|DP 1.25ghz|1.5gb Ram| |PTLE 6.1.2|Digi002r|Digimax| |Recent PC to Mac convert| |
ME works great for me. Very rarely has it ever crashed since I put it together.
It has worked well for me too. When I hear rants against ME, I suspect the problem lies elsewhere. I suppose it's possible to get a bad copy of an OS, but I'm no expert on that. I just know it's worked well in the two machines I've used it in.
~rh
rh music |
windows me seems to work better with some setups than it does with others. runs very well on my antique system (PIII 1000/Asus CUSL2) but on two other systems i put together which were pretty much the same spec (Asus CUSL2-C instead of CUSL2) it caused an unending line of problems. i couldn't explain this and neither could anyone i spoke to.
with an Athlon system, i got better results under ME than with 98SE so all in all, i think it is an improvement over the stock-standard 98 and 98SE. |
It's awful on my Intel 815 MB. Run away!
I get random shut downs occasionally when I have both Acid Pro and PTLE open. Over all it works fine, though.
I've been using ME for over a year now and have had no problems what-so-ever. I did read the suggestions for configuring my system and have nothing running in the background, no screen savers, not auto-updates or anything else, just like the config docs say.
Trying to run two CPU hungry apps simultaneously such as PT and Acid is asking for trouble. I am even reluctant to consult the on-line docs as any attempt to read these requires Acrobat Reader and that just takes a chunk out of the available memory leaving less room for PT. I have and do occasionally need to do this though and to insure that it causes the least bit of trouble possible, I have a separate drive for my audio files and I keep my documentation in a directory on the system drive so as to reduce the possibility od conflicts between audio functions and me referencing the docs at the same time. Just my $.02 worth. Good luck. |
10.7.5? How's it working for you? | Dizzi45Z | macOS | 10 | 10-16-2012 01:29 PM |
How's the expansion pack working out? | L-Dogg | Eleven Rack | 18 | 04-05-2011 01:20 PM |
How's the 8.03 cs2 working? | dave911 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-02-2010 07:34 AM |
How's your "under $600 desktop" working out? | Khatru | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-28-2006 05:52 PM |
Let's hear it: How's PT 5.1 working for you? | sidereal | Pro Tools TDM Systems (Mac) | 45 | 02-28-2001 12:08 AM |
