Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 02-18-2017, 01:10 PM
leopold55 leopold55 is offline
Default PT not recognizing MOTU24io
I hope this is the correct place to post this.
So we had the power suddenly go out and during a session last night. It quickly came back on but now ProTools (10) won't recognize my 24io that I'm running with a PCI-E card.
The 24io is fine, I was able to pull out my G5 with DP5 from storage that still has the PCI-X(I think that's what is in there) and finish the session using DP.
The card does show up in the system report as PCI1317a,5.
In PCI Audio Set up I can configure the card but in protools once I get into the I/O settings that doesn't seem to see the card/24io unit.
Any help you guys can offer I'd really appreciate.
Thanks,
Eddie
Old 02-20-2017, 11:43 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: PT not recognizing MOTU24io
Might be worth trying to trash your preferences. Then restart PT holding down the N key which it's loading. This will bring up the playback engine, where you can start over choosing your interface and setting p the I/O.
It's possible that something was corrupted when the power fluctuated, so wiping the settings and forcing the hardware initialization might get you back to where you were previously.
Will
System Details
PT 9 not recognizing 003 Telefella Windows 3 05-18-2011 01:23 PM
2 Problems: PT not recognizing plug-in and CPU not recognizing external hard drives jasonguitar Pro Tools M-Powered (Win) 0 06-28-2009 06:32 AM
HELP!! Not recognizing mic or something Crimnol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-26-2006 08:57 AM
PT Not recognizing 002 gmfilmco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-06-2005 09:40 AM
recognizing 888's detroitkruk Pro Tools TDM Systems (Mac) 3 08-11-2004 12:51 PM
