Serious Bug in 12HD
I've been dealing with this since upgrading.
Whatever I'm working on, if I take a break and leave 12.4HD open (typically an hour), when I come back and press play it's all of a sudden looking for a sync. I end up having to close the session which then brings on the spinning beach ball of death and then a force quit. If I look at the clock source it says internal. If i try to reselect internal the beachball comes up with a force quit to follow. This is BS for a Flagship app. Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Re: Serious Bug in 12HD
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
I was going to suggest the same.
In Energy settings, choose "Prevent computer from sleeping" Uncheck "Put hard disks to sleep when possible" Uncheck "Enable Power Nap" If that doesn't help, the next thing I would try is altering the clock master and making sure your doing a full loop sync. I have a very similar setup and I don't have this problem.... jeff |
Thanks. I have nothing on sleep but I did have wake for network access so I unchecked that. Let;s see what happens.
I've definitely experienced this. Exactly the same behavior.
Try this IF you have any spinner drives.
When you come back to your session, click on each drive to open a finder window. Even with the setting to stop drives going to sleep, some still do. Once all the finder windows open, try seeing if PT behaves normally.
I never leave a session open for any length of time longer than a bathroom break. I I go to lunch, I close the session(leaving PT open) and never have any issues(but leaving a session open for over an hour often will just lock up for me with previous versions, hence the new habit)
Pro tools 12hd upgrade questions?? | Adupr | Licensing & Accounts | 33 | 12-22-2015 06:21 PM |
Need help with upgrade decision from 11HD to 12HD | TrentWilliams | Pro Tools 12 | 7 | 11-27-2015 10:46 PM |
PT 12HD volume issues | mhender | Pro Tools 12 | 11 | 09-16-2015 01:35 AM |
Wanna knows what's new in PT 12 and PT 12HD?... | Justin1524 | Pro Tools 12 | 0 | 09-03-2015 02:18 PM |
ProTools 12HD does not see Intensity Pro | esparza audio | Pro Tools 12 | 1 | 04-05-2015 12:47 PM |
