Old 06-10-2008, 12:36 AM
Chris Doremus Chris Doremus is offline
Default Touching the fader and NOT seeing a dB level?????
I'm touching the fader on my D-control and I don't see a dB level in the scribble script. It doesn't work with any of the display modes. Please help. I wanna touch the fader and see the level in the scribble script. I tried rebooting the buckets also. No luck.
Old 06-10-2008, 08:45 PM
filmixer filmixer is offline
Default Re: Touching the fader and NOT seeing a dB level?????
Are you sure TchVal (Touch Value) is ON? In the soft key section under Operations, fourth page.
Mark Ettel C.A.S.
Old 06-14-2008, 11:07 PM
Mikey MTC Mikey MTC is offline
This started happening in some versions recently but appears to have been fixed in the new 7.4.2 version. It was a real PITA but could generally be fixed temporarily by throwing away your Pro Tools prefs. Of course that took all your prefs with it.
I first noticed this in 7.4.1 but 7.4.2 seems to have fixed it.
Old 06-15-2008, 12:12 AM
johnnyv johnnyv is offline
Yeah, it must be a version thing. Our rig is back two CS releases, I think...could be time to update to the latest CS. We'll report back!
Old 06-15-2008, 12:08 PM
uno1234 uno1234 is offline
This is one of many annoying bugs in the Icon. From DTS:
> The TchVal setting is not functioning on my D-Control or D-Command?
> Viewing the TchVal options, I notice that it is stuck on either,
> "On" "Off" "No Vol" or "Yes". When touching the fader it continues
> to display the track name and doesn't switch to showing the volume.
> Please reset to ICON firmware to factory default and re-flash the
> firmware. If the Surround Panner is not found after updating the D-
> Control or D-Command firmware, please use the following workaround
> as a resolution:
> 1. Re-load current firmware to the main, fader(s), and Surround Panner
> 2. Close Pro Tools
> 3. Remove the "Pro Tools v7.4 Preferences" file
> 4. Re-launch Pro Tools
> 5. Re-declare the ICON (D-Control or D-Command)
> This will restore the default ICON preferences, at which point both
> the SurroundPanner and Touch Val should be functioning properly. If
> the problem occurs again, one would only need to blow away the prefs
> and re-declare the ICON. There is no need for a firmware update again.
Old 06-15-2008, 10:36 PM
Thanks Uno,
One question...how do you reload the current firmware to the Icon? Do you download it off the Digi site?
Thanks for any info you have...
Old 06-16-2008, 12:23 AM
I think you hold down Mute-Solo-Select on each unit while powering it up (for the center section use the focus fader). Undeclare the Icon, power off, hold down mute-solo-select, power it all on, then redeclare, and Pro Tools will update firmware. I think. Digi, chime in if I am wrong.
Old 07-05-2008, 04:55 AM
Yeah, it seems as though once you're reloaded the D-Control firmware, if the problem comes up again, you have to close the session, trash JUST THE PRO TOOLS PREFERENCES using the Pro Tools "Pref trasher" program, then restart ProTools. If you do that, the touch value returns when you touch a fader.
Digi...the Icon is a main product for Digi, it would seem...can you help track down what's happening here?
Old 07-05-2008, 05:09 AM
Upgrade your Pro Tools - I'm pretty sure it's been fixed.
Old 07-05-2008, 05:38 AM
laki laki is offline
Running 7.4.2
I lose my TchVal at least once a day. Trashing prefs only, seems to fix it.
It happens so often, that I have written a Quickey that will set up all my prefs after they've been trashed.
I've given up on customizing my user soft keys because of how often I have to trash the prefs.
C24 select track when touching fader Jipi-sensei ICON & C|24 0 05-02-2013 03:46 AM
VCA Fader Level Jstil Pro Tools TDM Systems (Mac) 7 04-28-2011 01:21 PM
C-8 problems - touching fader 1 writes fader 2, etc MixerGuy ProControl, Control|24, Command|8 27 08-16-2007 10:23 AM
Master Fader Level TERRANCE Pro Tools M-Powered (Win) 2 06-01-2005 02:08 PM
Raising the level fader above 0 rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-05-2002 12:23 PM
